メインコンテンツにスキップ
Whirlpool Refrigerator Control Board Replacement
必要な工具と部品
  1. Whirlpool Refrigerator Control Board Replacement, Safety precautions: 手順 1、 1の画像 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Control Board Replacement, Unfasten the dispenser panels: 手順 2、 2の画像 1 Whirlpool Refrigerator Control Board Replacement, Unfasten the dispenser panels: 手順 2、 2の画像 2
    • The dispenser panel screws are located under the dispenser as if you're looking up into the dispenser tube (where the ice cubes and water come out).
    • Remove the screw(s) securing the two dispenser panels.
  3. Whirlpool Refrigerator Control Board Replacement, Remove the dispenser panels: 手順 3、 3の画像 1 Whirlpool Refrigerator Control Board Replacement, Remove the dispenser panels: 手順 3、 3の画像 2 Whirlpool Refrigerator Control Board Replacement, Remove the dispenser panels: 手順 3、 3の画像 3
    • Pull the dispenser panels straight down to separate them from the chassis.
    • Remove the dispenser panels.
  4. Whirlpool Refrigerator Control Board Replacement, Unfasten the control board: 手順 4、 1の画像 1
    • Remove the screw(s) securing the control board.
  5. Whirlpool Refrigerator Control Board Replacement: 手順 5、 3の画像 1 Whirlpool Refrigerator Control Board Replacement: 手順 5、 3の画像 2 Whirlpool Refrigerator Control Board Replacement: 手順 5、 3の画像 3
    • Tilt the bottom of the control board away from the chassis to release its clips.
    • Pull straight down to separate the control board enough to access its connectors.
  6. Whirlpool Refrigerator Control Board Replacement, Disconnect the control board: 手順 6、 3の画像 1 Whirlpool Refrigerator Control Board Replacement, Disconnect the control board: 手順 6、 3の画像 2 Whirlpool Refrigerator Control Board Replacement, Disconnect the control board: 手順 6、 3の画像 3
    • Disconnect the connectors attached to the control board.
  7. Whirlpool Refrigerator Control Board Replacement, Remove the control board: 手順 7、 1の画像 1
    • Remove the control board.
終わりに
Repair didn’t go as planned? Ask our Answers community for help.
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
nicO
メンバー登録日: 04/14/15
15,945 ポイント
89のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 29
過去 30 日: 200
今までの合計 4,979
