メインコンテンツにスキップ
Whirlpool Refrigerator Condenser Fan Replacement
必要な工具と部品
  1. Whirlpool Refrigerator Condenser Fan Replacement, Safety precautions: 手順 1、 1の画像 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Condenser Fan Replacement, Unfasten the rear panel: 手順 2、 3の画像 1 Whirlpool Refrigerator Condenser Fan Replacement, Unfasten the rear panel: 手順 2、 3の画像 2 Whirlpool Refrigerator Condenser Fan Replacement, Unfasten the rear panel: 手順 2、 3の画像 3
    • Remove the screw(s) securing the rear panel.
    • Loosen the screw securing the water hose enough for the rear panel to freely move.
  3. Whirlpool Refrigerator Condenser Fan Replacement, Remove the rear panel: 手順 3、 3の画像 1 Whirlpool Refrigerator Condenser Fan Replacement, Remove the rear panel: 手順 3、 3の画像 2 Whirlpool Refrigerator Condenser Fan Replacement, Remove the rear panel: 手順 3、 3の画像 3
    • Pull the rear panel off the chassis to remove it.
  4. Whirlpool Refrigerator Condenser Fan Replacement, Disconnect the condenser fan: 手順 4、 2の画像 1 Whirlpool Refrigerator Condenser Fan Replacement, Disconnect the condenser fan: 手順 4、 2の画像 2
    • Disconnect the connector attached to the condenser fan.
  5. Whirlpool Refrigerator Condenser Fan Replacement, Remove the condenser fan: 手順 5、 3の画像 1 Whirlpool Refrigerator Condenser Fan Replacement, Remove the condenser fan: 手順 5、 3の画像 2 Whirlpool Refrigerator Condenser Fan Replacement, Remove the condenser fan: 手順 5、 3の画像 3
    • Put on gloves before continuing, as the sheet metal and the fan itself are sharp.
    • Pull the condenser fan straight off its peg to remove it.
  6. Whirlpool Refrigerator Condenser Fan Replacement, Unfasten the condenser fan motor: 手順 6、 1の画像 1
    • Remove the screw(s) securing the condenser fan motor to the chassis.
  7. Whirlpool Refrigerator Condenser Fan Replacement, Remove the motor: 手順 7、 3の画像 1 Whirlpool Refrigerator Condenser Fan Replacement, Remove the motor: 手順 7、 3の画像 2 Whirlpool Refrigerator Condenser Fan Replacement, Remove the motor: 手順 7、 3の画像 3
    • Rotate the motor housing through its slot in the chassis.
    • Remove the motor.
終わりに
Repair didn’t go as planned? Ask our Answers community for help.
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
nicO
メンバー登録日: 04/14/15
15,927 ポイント
88のガイドは作成済み
チーム
Global Fixers Global Fixers人のメンバー
Community
33 メンバー
572のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 33
過去 30 日: 160
今までの合計 1,461
