メインコンテンツにスキップ
Weller WLC100 Soldering Station NTW56058 TRIAC 16amp switch Replacement
必要な工具と部品
  1. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement, NTW56058 TRIAC 16amp switch: 手順 1、 1の画像 1
    • Remove the knob from the adjustment dial.
  2. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 手順 2、 1の画像 1
    • Remove two 8.6 mm Phillips #1 screws from soldering station bottom.
  3. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 手順 3、 1の画像 1
    • Remove the rubber feet to access the remaining screws.
  4. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 手順 4、 1の画像 1
    • Remove the remaining two 8.6 mm Phillips #1 screws from soldering station bottom.
  5. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 手順 5、 1の画像 1
    • Separate the bottom and top half of the soldering station.
  6. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 手順 6、 1の画像 1
    • Remove the adjustable heat dial board.
  7. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 手順 7、 2の画像 1 Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 手順 7、 2の画像 2
    • Orient the new TRIAC switch the same way as the old TRIAC switch is located.
  8. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 手順 8、 2の画像 1 Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 手順 8、 2の画像 2
  9. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 手順 9、 1の画像 1
    • Remove the TRIAC switch when all the solder is removed from the pins.
  10. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 手順 10、 1の画像 1
    • Insert the new TRIAC switch into the three holes left when you removed the old TRIAC switch.
  11. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 手順 11、 1の画像 1
    • Solder the new TRIAC switch onto board.
  12. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 手順 12、 1の画像 1
    • Verify all three pins are soldered in and the solder is not touching the other pins.
  13. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 手順 13、 1の画像 1
    • Re-install the board into the soldering station.
  14. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 手順 14、 1の画像 1
    • Push the knob into the hole so that is it protruding out of the other side.
  15. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 手順 15、 1の画像 1
    • Verify the knob is sticking out of the other side of soldering station.
  16. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 手順 16、 1の画像 1
    • Replace the dial onto the knob.
  17. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: 手順 17、 1の画像 1
    • Replace the bottom and replace all four screws and rubber feet, reversing steps four though two.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Terence Ryan
メンバー登録日: 02/16/21
292 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team S50-G14, Willis Spring 2021 University of Memphis, Team S50-G14, Willis Spring 2021人のメンバー
UM-WILLIS-S21S50G14
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 28
今までの合計 1,318
