メインコンテンツにスキップ
WarioWare: Twisted! Rumble Motor Replacement
必要な工具と部品
  1. WarioWare: Twisted! Rumble Motor Replacement, Rumble Motor: 手順 1、 2の画像 1 WarioWare: Twisted! Rumble Motor Replacement, Rumble Motor: 手順 1、 2の画像 2
    • Use a Tri-point Y0 screwdriver to remove the single 3 mm screw located at the back of the game.
    • Remove the cover to expose the control module electronics board underneath.
  2. WarioWare: Twisted! Rumble Motor Replacement: 手順 2、 3の画像 1 WarioWare: Twisted! Rumble Motor Replacement: 手順 2、 3の画像 2 WarioWare: Twisted! Rumble Motor Replacement: 手順 2、 3の画像 3
    • Heat up the soldering iron to approximately 350 degrees Fahrenheit.
    • Remove the rumble motor from the slot.
    • For more information on soldering, refer to How to Solder and Desolder Connections.
    • Apply the tip of the soldering iron to the connection points, causing the red and blue wires to melt and detach.
    • Separate the old rumble motor from the board and set it aside.
    • The soldering iron will be very hot. Do not touch the tip of the iron. It will cause severe burns.
  3. WarioWare: Twisted! Rumble Motor Replacement: 手順 3、 3の画像 1 WarioWare: Twisted! Rumble Motor Replacement: 手順 3、 3の画像 2 WarioWare: Twisted! Rumble Motor Replacement: 手順 3、 3の画像 3
    • Use your hands to remove the black sleeve from the old rumble motor.
    • Set the old rumble motor aside.
    • Use your hands to place the black sleeve onto the new rumble motor you're using.
  4. WarioWare: Twisted! Rumble Motor Replacement: 手順 4、 3の画像 1 WarioWare: Twisted! Rumble Motor Replacement: 手順 4、 3の画像 2 WarioWare: Twisted! Rumble Motor Replacement: 手順 4、 3の画像 3
    • Place the red wire onto the plus (left) side, and the blue wire onto the minus (right) side.
    • To reattach the red and blue wires, carefully bring the tip of the soldering iron into contact with the connection points.
    • The soldering iron will be hot. Do not touch the tip of the iron.
    • Place the new rumble motor back in its slot.
    • Turn off the soldering iron after you finish this step.
  5. WarioWare: Twisted! Rumble Motor Replacement: 手順 5、 3の画像 1 WarioWare: Twisted! Rumble Motor Replacement: 手順 5、 3の画像 2 WarioWare: Twisted! Rumble Motor Replacement: 手順 5、 3の画像 3
    • Put the cover back on the game.
    • Gently push the two sides back together.
  6. WarioWare: Twisted! Rumble Motor Replacement: 手順 6、 2の画像 1 WarioWare: Twisted! Rumble Motor Replacement: 手順 6、 2の画像 2
    • Use your Tri-point Y0 screwdriver to screw the single 3 mm screw back into place.
    • Test the game to make sure the problem is fixed and you should be ready to play!
終わりに
I hope this guide solved your problem, and your game should work like new again!
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Brent Thompson
メンバー登録日: 06/21/23
133 ポイント
1ガイドが承認済み
チーム
Austin Community College, Team 4-7, Watkins Summer 2023 Austin Community College, Team 4-7, Watkins Summer 2023人のメンバー
AUSTINCC-WATKINS-SU23S4G7
1 メンバー
1のガイドは作成済み
コメント 1 件
Nice post and please provide more information. Thanks for sharing.
cunez - 返信
コメントを追加
統計データ:
過去 24時間: 18
過去 7 日: 39
過去 30 日: 93
今までの合計 928
