メインコンテンツにスキップ
Wacom Intuos Pro Motherboard Replacement
必要な工具と部品
  1. Wacom Intuos Pro Motherboard Replacement, Battery: 手順 1、 3の画像 1 Wacom Intuos Pro Motherboard Replacement, Battery: 手順 1、 3の画像 2 Wacom Intuos Pro Motherboard Replacement, Battery: 手順 1、 3の画像 3
    • Orient the device so the bottom casing is facing upwards.
    • Use your fingers to gently pull on the rubber covers on the bottom of the device to remove them.
  2. Wacom Intuos Pro Motherboard Replacement: 手順 2、 3の画像 1 Wacom Intuos Pro Motherboard Replacement: 手順 2、 3の画像 2 Wacom Intuos Pro Motherboard Replacement: 手順 2、 3の画像 3
    • Remove the four 4mm screws from underneath the rubber feet using a Phillips #00 screwdriver.
  3. Wacom Intuos Pro Motherboard Replacement: 手順 3、 2の画像 1 Wacom Intuos Pro Motherboard Replacement: 手順 3、 2の画像 2
    • Insert the iFixit Opening Tool between the front and back cover of the device in order to snap and separate the type locks from around the edges.
    • Use the iFixit Opening Tool all the way around the edges until all the snaps have been released.
    • While going around the edges, make sure you have a tight grip to keep the device from sliding.
  4. Wacom Intuos Pro Motherboard Replacement: 手順 4、 2の画像 1 Wacom Intuos Pro Motherboard Replacement: 手順 4、 2の画像 2
    • Remove the case backing from the rear of the device with your hands so the internal components are exposed.
  5. Wacom Intuos Pro Motherboard Replacement: 手順 5、 2の画像 1 Wacom Intuos Pro Motherboard Replacement: 手順 5、 2の画像 2
    • If not already done, desolder the three colored cables that connect the battery to the motherboard.
    • After desoldering the battery, carefully remove it.
    • Be careful when handling the soldering iron given it's high operating temperature and the possibility for it to damage other components.
    • For help soldering, check out our How to Solder and Desolder Connections guide.
  6. Wacom Intuos Pro Motherboard Replacement, Motherboard: 手順 6、 1の画像 1
    • Gently pull the blue tabs on the four ribbon cables from the ZIF connectors on the motherboard.
  7. Wacom Intuos Pro Motherboard Replacement: 手順 7、 1の画像 1
    • Remove the 4.5mm screw holding down the motherboard using a Phillips #00 screwdriver.
  8. Wacom Intuos Pro Motherboard Replacement: 手順 8、 1の画像 1
    • Remove all three ribbon cables by gently pulling on their respective ''Black" and "Blue" tabs.
  9. Wacom Intuos Pro Motherboard Replacement: 手順 9、 1の画像 1
    • Gently remove the motherboard from the case.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Donaven Williams
メンバー登録日: 09/20/21
115 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 13
過去 30 日: 54
今までの合計 920
