メインコンテンツにスキップ
Wacom Intuos Pro Battery Replacement
必要な工具と部品
  1. Wacom Intuos Pro Battery Replacement, Battery: 手順 1、 3の画像 1 Wacom Intuos Pro Battery Replacement, Battery: 手順 1、 3の画像 2 Wacom Intuos Pro Battery Replacement, Battery: 手順 1、 3の画像 3
    • Orient the device so the bottom casing is facing upwards.
    • Use your fingers to gently pull on the rubber covers on the bottom of the device to remove them.
  2. Wacom Intuos Pro Battery Replacement: 手順 2、 3の画像 1 Wacom Intuos Pro Battery Replacement: 手順 2、 3の画像 2 Wacom Intuos Pro Battery Replacement: 手順 2、 3の画像 3
    • Remove the four 4mm screws from underneath the rubber feet using a Phillips #00 screwdriver.
  3. Wacom Intuos Pro Battery Replacement: 手順 3、 2の画像 1 Wacom Intuos Pro Battery Replacement: 手順 3、 2の画像 2
    • Insert the iFixit Opening Tool between the front and back cover of the device in order to snap and separate the type locks from around the edges.
    • Use the iFixit Opening Tool all the way around the edges until all the snaps have been released.
    • While going around the edges, make sure you have a tight grip to keep the device from sliding.
  4. Wacom Intuos Pro Battery Replacement: 手順 4、 2の画像 1 Wacom Intuos Pro Battery Replacement: 手順 4、 2の画像 2
    • Remove the case backing from the rear of the device with your hands so the internal components are exposed.
  5. Wacom Intuos Pro Battery Replacement: 手順 5、 2の画像 1 Wacom Intuos Pro Battery Replacement: 手順 5、 2の画像 2
    • If not already done, desolder the three colored cables that connect the battery to the motherboard.
    • After desoldering the battery, carefully remove it.
    • Be careful when handling the soldering iron given it's high operating temperature and the possibility for it to damage other components.
    • For help soldering, check out our How to Solder and Desolder Connections guide.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
chris peterson
メンバー登録日: 01/22/20
198 ポイント
1ガイドが承認済み
4 件のコメント
thank you so much. I plan to buy this wacom, however I had the doubt if better the old version that has extractable battery, but with this post, I can go for the new one
Sebastian Ramirez - 返信
Do you know where can I find the battery replacement?
Valerio _ - 返信
Has anyone got a lint to the replacement battery?
Luca Di Meo - 返信
PTH-660 works fine without the battery, just remove it and use it with USB cable
Luca Di Meo - 返信
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 40
過去 30 日: 200
今までの合計 6,447
