メインコンテンツにスキップ
Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement
必要な工具と部品
  1. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Safety precautions: 手順 1、 2の画像 1 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Safety precautions: 手順 1、 2の画像 2
    • Before you begin, be sure that the engine is powered off and is cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  2. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Loosen the belt guard: 手順 2、 1の画像 1
    • Use a 1/2" socket and wrench to loosen the two bolts securing the belt guard.
    • The bolts are captive and should not be removed.
  3. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the belt guard: 手順 3、 2の画像 1 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the belt guard: 手順 3、 2の画像 2
    • Remove the belt guard.
  4. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the drive belt: 手順 4、 3の画像 1 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the drive belt: 手順 4、 3の画像 2 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Remove the drive belt: 手順 4、 3の画像 3
    • Use scissors or a blade to cut the drive belt.
    • Remove the drive belt.
  5. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement, Install a replacement belt: 手順 5、 1の画像 1
    • Loop the replacement belt onto the small pulley.
  6. Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement: 手順 6、 3の画像 1 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement: 手順 6、 3の画像 2 Wacker Compactor Plate VP1550AW 2014 V-Belt Replacement: 手順 6、 3の画像 3
    • Replacing the belt poses a substantial pinching hazard. Wear safety gloves and be mindful where you position your fingers.
    • Guide the belt over the top of the clutch pulley.
    • Loop the belt underneath the pulley axle.
    • Rotate the pulley slowly and guide the built into the groove.
    • Getting the replacement belt back onto the drive pulley requires considerable strength.
終わりに
作成者
1人の作成者と共同作成されました。
Arthur Shi
メンバー登録日: 01/03/18
254,564 ポイント
529のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,430のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 36
今までの合計 3,029
