メインコンテンツにスキップ
WRS315SDHW Temperature Control Board Replacement
必要な工具と部品
  1. WRS315SDHW Temperature Control Board Replacement, Safety precautions: 手順 1、 1の画像 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Temperature Control Board Replacement, Open the doors: 手順 2、 3の画像 1 WRS315SDHW Temperature Control Board Replacement, Open the doors: 手順 2、 3の画像 2 WRS315SDHW Temperature Control Board Replacement, Open the doors: 手順 2、 3の画像 3
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Temperature Control Board Replacement, Unfasten the temperature control board assembly: 手順 3、 2の画像 1 WRS315SDHW Temperature Control Board Replacement, Unfasten the temperature control board assembly: 手順 3、 2の画像 2
    • Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the 22.3 mm-long screw securing the temperature control board assembly.
  4. WRS315SDHW Temperature Control Board Replacement, Reposition the assembly: 手順 4、 3の画像 1 WRS315SDHW Temperature Control Board Replacement, Reposition the assembly: 手順 4、 3の画像 2 WRS315SDHW Temperature Control Board Replacement, Reposition the assembly: 手順 4、 3の画像 3
    • Pull the temperature control board assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  5. WRS315SDHW Temperature Control Board Replacement, Disconnect the temperature control board: 手順 5、 3の画像 1 WRS315SDHW Temperature Control Board Replacement, Disconnect the temperature control board: 手順 5、 3の画像 2 WRS315SDHW Temperature Control Board Replacement, Disconnect the temperature control board: 手順 5、 3の画像 3
    • Disconnect the two spade connectors attached to the temperature control board assembly.
  6. WRS315SDHW Temperature Control Board Replacement, Remove the assembly: 手順 6、 1の画像 1
    • Remove the temperature control board assembly.
  7. WRS315SDHW Temperature Control Board Replacement, Separate the temperature control board: 手順 7、 3の画像 1 WRS315SDHW Temperature Control Board Replacement, Separate the temperature control board: 手順 7、 3の画像 2 WRS315SDHW Temperature Control Board Replacement, Separate the temperature control board: 手順 7、 3の画像 3
    • Use a flathead screwdriver, or a similar tool, to compress the plastic clip securing the temperature control board.
    • Use another flathead screwdriver to pry up the board from its housing.
  8. WRS315SDHW Temperature Control Board Replacement, Remove the temperature control board: 手順 8、 1の画像 1
    • Pull the temperature control board straight out of its housing to remove it.
終わりに
Repair didn’t go as planned? Ask our Answers community for help.
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
nicO
メンバー登録日: 04/14/15
15,945 ポイント
89のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 213
