メインコンテンツにスキップ
WRS315SDHW Inlet Valve Assembly Replacement
必要な工具と部品
  1. WRS315SDHW Inlet Valve Assembly Replacement, Safety precautions: 手順 1、 1の画像 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Inlet Valve Assembly Replacement, Unfasten the rear panel: 手順 2、 3の画像 1 WRS315SDHW Inlet Valve Assembly Replacement, Unfasten the rear panel: 手順 2、 3の画像 2 WRS315SDHW Inlet Valve Assembly Replacement, Unfasten the rear panel: 手順 2、 3の画像 3
    • Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the seven 16.2 mm-long screws securing the rear panel.
    • Use a 1/4 inch socket wrench to loosen the screw securing the water hose enough for the rear panel to freely move.
  3. WRS315SDHW Inlet Valve Assembly Replacement, Remove the rear panel: 手順 3、 3の画像 1 WRS315SDHW Inlet Valve Assembly Replacement, Remove the rear panel: 手順 3、 3の画像 2 WRS315SDHW Inlet Valve Assembly Replacement, Remove the rear panel: 手順 3、 3の画像 3
    • Pull the rear panel off the chassis to remove it.
  4. WRS315SDHW Inlet Valve Assembly Replacement, Remove the clip: 手順 4、 2の画像 1 WRS315SDHW Inlet Valve Assembly Replacement, Remove the clip: 手順 4、 2の画像 2
    • Use needle nose pliers, or your fingers, to remove the plastic clip on the inlet valve assembly.
  5. WRS315SDHW Inlet Valve Assembly Replacement, Disconnect the front water hose: 手順 5、 3の画像 1 WRS315SDHW Inlet Valve Assembly Replacement, Disconnect the front water hose: 手順 5、 3の画像 2 WRS315SDHW Inlet Valve Assembly Replacement, Disconnect the front water hose: 手順 5、 3の画像 3
    • Push the plastic ring above the front water hose to release its clips.
    • As you push the ring, pull the water hose downward to disconnect it.
    • Repeat the disconnection procedure for the other water hose on the inlet valve assembly.
  6. WRS315SDHW Inlet Valve Assembly Replacement, Unfasten the inlet valve assembly: 手順 6、 1の画像 1
    • Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the inlet valve assembly.
  7. WRS315SDHW Inlet Valve Assembly Replacement, Reposition the inlet valve assembly: 手順 7、 3の画像 1 WRS315SDHW Inlet Valve Assembly Replacement, Reposition the inlet valve assembly: 手順 7、 3の画像 2 WRS315SDHW Inlet Valve Assembly Replacement, Reposition the inlet valve assembly: 手順 7、 3の画像 3
    • Pull the inlet valve assembly off its slot in the chassis and rest it on the floor.
  8. WRS315SDHW Inlet Valve Assembly Replacement: 手順 8、 2の画像 1 WRS315SDHW Inlet Valve Assembly Replacement: 手順 8、 2の画像 2
    • Place a clean and dry rag under the inlet valve assembly before continuing.
  9. WRS315SDHW Inlet Valve Assembly Replacement, Remove the clip: 手順 9、 2の画像 1 WRS315SDHW Inlet Valve Assembly Replacement, Remove the clip: 手順 9、 2の画像 2
    • Use needle nose pliers, or your hands, to pull the blue clip off the rear water hose.
  10. WRS315SDHW Inlet Valve Assembly Replacement: 手順 10、 3の画像 1 WRS315SDHW Inlet Valve Assembly Replacement: 手順 10、 3の画像 2 WRS315SDHW Inlet Valve Assembly Replacement: 手順 10、 3の画像 3
    • Push the yellow plastic ring above the rear water hose to release its clips.
    • As you push the ring, pull the water hose away from the inlet valve assembly to disconnect it.
  11. WRS315SDHW Inlet Valve Assembly Replacement, Disconnect the assembly wire connector: 手順 11、 3の画像 1 WRS315SDHW Inlet Valve Assembly Replacement, Disconnect the assembly wire connector: 手順 11、 3の画像 2 WRS315SDHW Inlet Valve Assembly Replacement, Disconnect the assembly wire connector: 手順 11、 3の画像 3
    • Use a flathead screwdriver, or a similar tool, to disconnect the inlet valve assembly wire connector.
  12. WRS315SDHW Inlet Valve Assembly Replacement, Remove the inlet valve assembly: 手順 12、 1の画像 1
    • Remove the inlet valve assembly from the chassis.
終わりに
Repair didn’t go as planned? Ask our Answers community for help.
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
nicO
メンバー登録日: 04/14/15
15,945 ポイント
89のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 14
今までの合計 300
