メインコンテンツにスキップ
WRS315SDHW Icemaker Assembly Replacement
必要な工具と部品
  1. WRS315SDHW Icemaker Assembly Replacement, Safety precautions: 手順 1、 1の画像 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Icemaker Assembly Replacement, Open the doors: 手順 2、 3の画像 1 WRS315SDHW Icemaker Assembly Replacement, Open the doors: 手順 2、 3の画像 2 WRS315SDHW Icemaker Assembly Replacement, Open the doors: 手順 2、 3の画像 3
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Icemaker Assembly Replacement, Remove the icemaker tray: 手順 3、 2の画像 1 WRS315SDHW Icemaker Assembly Replacement, Remove the icemaker tray: 手順 3、 2の画像 2
    • Pull the icemaker tray completely out of its slot in the chassis.
  4. WRS315SDHW Icemaker Assembly Replacement, Unfasten the icemaker assembly: 手順 4、 2の画像 1 WRS315SDHW Icemaker Assembly Replacement, Unfasten the icemaker assembly: 手順 4、 2の画像 2
    • Use a 1/4 inch socket wrench to remove the three screws securing the icemaker assembly (shown with the assembly removed):
    • Two 23.9 mm-long screws
    • One 16.7 mm-long screw
  5. WRS315SDHW Icemaker Assembly Replacement, Reposition the icemaker assembly: 手順 5、 3の画像 1 WRS315SDHW Icemaker Assembly Replacement, Reposition the icemaker assembly: 手順 5、 3の画像 2 WRS315SDHW Icemaker Assembly Replacement, Reposition the icemaker assembly: 手順 5、 3の画像 3
    • Pull the icemaker assembly toward the right edge of the refrigerator to release it from its slot in the chassis.
    • Let the icemaker assembly hang to access its connector.
  6. WRS315SDHW Icemaker Assembly Replacement, Disconnect the icemaker assembly: 手順 6、 3の画像 1 WRS315SDHW Icemaker Assembly Replacement, Disconnect the icemaker assembly: 手順 6、 3の画像 2 WRS315SDHW Icemaker Assembly Replacement, Disconnect the icemaker assembly: 手順 6、 3の画像 3
    • Disconnect the spade connector attached to the icemaker assembly.
  7. WRS315SDHW Icemaker Assembly Replacement, Remove the icemaker assembly: 手順 7、 1の画像 1
    • Remove the icemaker assembly.
終わりに
Repair didn’t go as planned? Ask our Answers community for help.
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
nicO
メンバー登録日: 04/14/15
15,945 ポイント
89のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 15
今までの合計 500
