はじめに
Use this guide to replace the door light in your Whirlpool WRS315SDHW Refrigerator.
The door light illuminates the right side of the refrigerator. If the lighting in your refrigerator is dim or dark, then the door light might be broken.
Note: Some photos show the doors removed for clarity purposes. Removing them is not required and will not change the procedure.
必要な工具と部品
Carefully insert a flathead screwdriver, or a similar tool, between the door light and the chassis.
Pry up to separate the door light enough so you can grip it with your fingers.
Repair didn’t go as planned? Ask our Answers community for help.
ある他の人がこのガイドを完成しました。
