メインコンテンツにスキップ
WRS315SDHW Dispenser Solenoid Replacement
必要な工具と部品
  1. WRS315SDHW Dispenser Solenoid Replacement, Safety precautions: 手順 1、 1の画像 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Dispenser Solenoid Replacement, Open the doors: 手順 2、 3の画像 1 WRS315SDHW Dispenser Solenoid Replacement, Open the doors: 手順 2、 3の画像 2 WRS315SDHW Dispenser Solenoid Replacement, Open the doors: 手順 2、 3の画像 3
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Dispenser Solenoid Replacement, Remove the icemaker tray: 手順 3、 2の画像 1 WRS315SDHW Dispenser Solenoid Replacement, Remove the icemaker tray: 手順 3、 2の画像 2
    • Pull the icemaker tray completely out of its slot in the chassis.
  4. WRS315SDHW Dispenser Solenoid Replacement, Unfasten the icemaker assembly: 手順 4、 2の画像 1 WRS315SDHW Dispenser Solenoid Replacement, Unfasten the icemaker assembly: 手順 4、 2の画像 2
    • Use a 1/4 inch socket wrench to remove the three screws securing the icemaker assembly (shown with the assembly removed):
    • Two 23.9 mm-long screws
    • One 16.7 mm-long screw
  5. WRS315SDHW Dispenser Solenoid Replacement, Reposition the icemaker assembly: 手順 5、 3の画像 1 WRS315SDHW Dispenser Solenoid Replacement, Reposition the icemaker assembly: 手順 5、 3の画像 2 WRS315SDHW Dispenser Solenoid Replacement, Reposition the icemaker assembly: 手順 5、 3の画像 3
    • Pull the icemaker assembly toward the right edge of the refrigerator to release it from its slot in the chassis.
    • Let the icemaker assembly hang to access its connector.
  6. WRS315SDHW Dispenser Solenoid Replacement, Disconnect the icemaker assembly: 手順 6、 3の画像 1 WRS315SDHW Dispenser Solenoid Replacement, Disconnect the icemaker assembly: 手順 6、 3の画像 2 WRS315SDHW Dispenser Solenoid Replacement, Disconnect the icemaker assembly: 手順 6、 3の画像 3
    • Disconnect the spade connector attached to the icemaker assembly.
  7. WRS315SDHW Dispenser Solenoid Replacement, Remove the icemaker assembly: 手順 7、 1の画像 1
    • Remove the icemaker assembly.
  8. WRS315SDHW Dispenser Solenoid Replacement, Unfasten the icemaker auger assembly: 手順 8、 1の画像 1
    • Use a 1/4 inch socket wrench to remove the four screws securing the icemaker auger assembly:
    • Two 24.1 mm-long screws
    • Two 16.5 mm-long screws
  9. WRS315SDHW Dispenser Solenoid Replacement, Reposition the icemaker auger assembly: 手順 9、 3の画像 1 WRS315SDHW Dispenser Solenoid Replacement, Reposition the icemaker auger assembly: 手順 9、 3の画像 2 WRS315SDHW Dispenser Solenoid Replacement, Reposition the icemaker auger assembly: 手順 9、 3の画像 3
    • Pull the icemaker auger assembly off of its slot in the chassis.
    • Let the assembly hang to access its connector.
  10. WRS315SDHW Dispenser Solenoid Replacement, Disconnect the icemaker auger assembly: 手順 10、 3の画像 1 WRS315SDHW Dispenser Solenoid Replacement, Disconnect the icemaker auger assembly: 手順 10、 3の画像 2 WRS315SDHW Dispenser Solenoid Replacement, Disconnect the icemaker auger assembly: 手順 10、 3の画像 3
    • Use a flathead screwdriver, or a similar tool, to compress the connector attached to the icemaker auger assembly.
    • Use your hands to disconnect the assembly connector.
  11. WRS315SDHW Dispenser Solenoid Replacement, Remove the icemaker auger assembly: 手順 11、 1の画像 1
    • Remove the icemaker auger assembly.
  12. WRS315SDHW Dispenser Solenoid Replacement, Remove the dispenser: 手順 12、 3の画像 1 WRS315SDHW Dispenser Solenoid Replacement, Remove the dispenser: 手順 12、 3の画像 2 WRS315SDHW Dispenser Solenoid Replacement, Remove the dispenser: 手順 12、 3の画像 3
    • Slide the dispenser head out of its slot in the icemaker auger assembly.
  13. WRS315SDHW Dispenser Solenoid Replacement: 手順 13、 2の画像 1 WRS315SDHW Dispenser Solenoid Replacement: 手順 13、 2の画像 2
    • Remove the dispenser head out of its metal solenoid cube.
  14. WRS315SDHW Dispenser Solenoid Replacement, Remove the tape: 手順 14、 3の画像 1 WRS315SDHW Dispenser Solenoid Replacement, Remove the tape: 手順 14、 3の画像 2 WRS315SDHW Dispenser Solenoid Replacement, Remove the tape: 手順 14、 3の画像 3
    • Peel the tape off the solenoid connector.
    • Set the tape aside. You'll reuse it during reassembly.
  15. WRS315SDHW Dispenser Solenoid Replacement, Disconnect the solenoid: 手順 15、 3の画像 1 WRS315SDHW Dispenser Solenoid Replacement, Disconnect the solenoid: 手順 15、 3の画像 2 WRS315SDHW Dispenser Solenoid Replacement, Disconnect the solenoid: 手順 15、 3の画像 3
    • Pull the solenoid spade connector straight out of the solenoid to disconnect it.
終わりに
Repair didn’t go as planned? Ask our Answers community for help.
作成者
2人の作成者と共同で作成されました。
nicO
メンバー登録日: 04/14/15
15,927 ポイント
88のガイドは作成済み
チーム
Global Fixers Global Fixers人のメンバー
Community
33 メンバー
577のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 68
