メインコンテンツにスキップ
WRS315SDHW Control Board Replacement
必要な工具と部品
  1. WRS315SDHW Control Board Replacement, Safety precautions: 手順 1、 1の画像 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Control Board Replacement, Unfasten the dispenser panels: 手順 2、 2の画像 1 WRS315SDHW Control Board Replacement, Unfasten the dispenser panels: 手順 2、 2の画像 2
    • The dispenser panel screws are located under the dispenser as if you're looking up into the dispenser tube (where the ice cubes and water come out).
    • Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the two dispenser panels.
  3. WRS315SDHW Control Board Replacement, Remove the dispenser panels: 手順 3、 3の画像 1 WRS315SDHW Control Board Replacement, Remove the dispenser panels: 手順 3、 3の画像 2 WRS315SDHW Control Board Replacement, Remove the dispenser panels: 手順 3、 3の画像 3
    • Pull the dispenser panels straight down to separate them from the chassis.
    • Remove the dispenser panels.
  4. WRS315SDHW Control Board Replacement, Unfasten the control board: 手順 4、 1の画像 1
    • Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the control board.
  5. WRS315SDHW Control Board Replacement: 手順 5、 3の画像 1 WRS315SDHW Control Board Replacement: 手順 5、 3の画像 2 WRS315SDHW Control Board Replacement: 手順 5、 3の画像 3
    • Tilt the bottom of the control board away from the chassis to release its clips.
    • Pull straight down to separate the control board enough to access its connectors.
  6. WRS315SDHW Control Board Replacement, Disconnect the control board: 手順 6、 3の画像 1 WRS315SDHW Control Board Replacement, Disconnect the control board: 手順 6、 3の画像 2 WRS315SDHW Control Board Replacement, Disconnect the control board: 手順 6、 3の画像 3
    • Disconnect the large connector attached to the right edge of the control board.
  7. WRS315SDHW Control Board Replacement: 手順 7、 2の画像 1 WRS315SDHW Control Board Replacement: 手順 7、 2の画像 2
    • Disconnect the small connector attached to the left edge of the control board.
  8. WRS315SDHW Control Board Replacement, Remove the control board: 手順 8、 1の画像 1
    • Remove the control board.
終わりに
Repair didn’t go as planned? Ask our Answers community for help.
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
nicO
メンバー登録日: 04/14/15
15,945 ポイント
89のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 14
今までの合計 635
