メインコンテンツにスキップ
Vtech Kidizoom Smart Watch DX Circuit Board Replacement
必要な工具と部品
  1. Vtech Kidizoom Smart Watch DX Circuit Board Replacement, Master Switch: 手順 1、 1の画像 1
    • Make sure the master switch is "OFF" before disassembly, to avoid an electric shock.
    • Flip the watch over with the back facing up.
  2. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: 手順 2、 1の画像 1
    • Remove the four 6.0 mm screws on the back plate with the Phillips #00 screwdriver.
  3. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: 手順 3、 1の画像 1
    • Gently pull the back plate from the watch casing.
  4. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: 手順 4、 2の画像 1 Vtech Kidizoom Smart Watch DX Circuit Board Replacement: 手順 4、 2の画像 2
    • Lift the master switch from the circuit board.
  5. Vtech Kidizoom Smart Watch DX Circuit Board Replacement, Circuit Board: 手順 5、 2の画像 1 Vtech Kidizoom Smart Watch DX Circuit Board Replacement, Circuit Board: 手順 5、 2の画像 2
    • The speaker wires are fragile. They may break if excessive force is used to remove the circuit board.
    • Removal of the circuit board requires soldering.
    • Gently push on the display from the front, near the camera. The circuit board and display will pop out through the back.
  6. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: 手順 6、 1の画像 1
    • Lift the circuit board carefully from the casing, without breaking or detaching the speaker wires at the bottom of the circuit board.
  7. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: 手順 7、 1の画像 1
    • Note which wire is connected to which lead before continuing. There are no markers on the circuit board to indicate where each wire belongs.
    • De-solder the black speaker wire from the circuit board.
  8. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: 手順 8、 1の画像 1
    • De-solder the red speaker wire, as in the previous step.
  9. Vtech Kidizoom Smart Watch DX Circuit Board Replacement: 手順 9、 1の画像 1
    • Wait for the solder to cool down and solidify, then remove the circuit board from the casing.
終わりに
7 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Jordan RiberSmith
メンバー登録日: 01/20/16
755 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 10-6, Remmell Spring 2016 USF Tampa, Team 10-6, Remmell Spring 2016人のメンバー
USFT-REMMELL-S16S10G6
4 メンバー
12のガイドは作成済み
2 件のコメント
Where can I buy the circuit board ?? Please send me a link or just post it please. Thanks
Jamar Mckay - 返信
Where can I buy replacement and how much should it cost?
Marisol Pelayo - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 18
過去 30 日: 64
今までの合計 9,994
