メインコンテンツにスキップ
Vtech Kidizoom Smart Watch DX Buttons Replacement
必要な工具と部品
  1. Vtech Kidizoom Smart Watch DX Buttons Replacement, Master Switch: 手順 1、 1の画像 1
    • Make sure the master switch is "OFF" before disassembly, to avoid an electric shock.
    • Flip the watch over with the back facing up.
  2. Vtech Kidizoom Smart Watch DX Buttons Replacement: 手順 2、 1の画像 1
    • Remove the four 6.0 mm screws on the back plate with the Phillips #00 screwdriver.
  3. Vtech Kidizoom Smart Watch DX Buttons Replacement: 手順 3、 1の画像 1
    • Gently pull the back plate from the watch casing.
  4. Vtech Kidizoom Smart Watch DX Buttons Replacement: 手順 4、 2の画像 1 Vtech Kidizoom Smart Watch DX Buttons Replacement: 手順 4、 2の画像 2
    • Lift the master switch from the circuit board.
  5. Vtech Kidizoom Smart Watch DX Buttons Replacement, Circuit Board: 手順 5、 2の画像 1 Vtech Kidizoom Smart Watch DX Buttons Replacement, Circuit Board: 手順 5、 2の画像 2
    • The speaker wires are fragile. They may break if excessive force is used to remove the circuit board.
    • Removal of the circuit board requires soldering.
    • Gently push on the display from the front, near the camera. The circuit board and display will pop out through the back.
  6. Vtech Kidizoom Smart Watch DX Buttons Replacement: 手順 6、 1の画像 1
    • Lift the circuit board carefully from the casing, without breaking or detaching the speaker wires at the bottom of the circuit board.
  7. Vtech Kidizoom Smart Watch DX Buttons Replacement: 手順 7、 1の画像 1
    • Note which wire is connected to which lead before continuing. There are no markers on the circuit board to indicate where each wire belongs.
    • De-solder the black speaker wire from the circuit board.
  8. Vtech Kidizoom Smart Watch DX Buttons Replacement: 手順 8、 1の画像 1
    • De-solder the red speaker wire, as in the previous step.
  9. Vtech Kidizoom Smart Watch DX Buttons Replacement: 手順 9、 1の画像 1
    • Wait for the solder to cool down and solidify, then remove the circuit board from the casing.
  10. Vtech Kidizoom Smart Watch DX Buttons Replacement, Buttons: 手順 10、 1の画像 1
    • Use the the tweezers to pull off the blue rubber cover behind the button.
    • The blue cover is adhesive, so you can stick it back onto the back of the buttons after replacement.
  11. Vtech Kidizoom Smart Watch DX Buttons Replacement: 手順 11、 1の画像 1
    • Use tweezers to separate the backside tab from the front side of the button.
  12. Vtech Kidizoom Smart Watch DX Buttons Replacement: 手順 12、 1の画像 1
    • Push the other half of the button out of the casing.
    • Repeat steps 11 and 12 for all buttons.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Mohammed Alyaarubi
メンバー登録日: 01/20/16
341 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 10-6, Remmell Spring 2016 USF Tampa, Team 10-6, Remmell Spring 2016人のメンバー
USFT-REMMELL-S16S10G6
4 メンバー
6のガイドは作成済み
コメント 1 件
Where can you buy the replacement cover?
Katrina Nullatamby - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 18
今までの合計 5,416
