はじめに
A faulty volume switch can often lead to distorted audio or even no audio at all. This guide is designed to show how to correctly replace the volume switch for your drum set in order to restore sound and proper function.
必要な工具と部品
Locate the battery panel that is centered between the three leg supports at the bottom of the drum set.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
