はじめに
In order to replace the speaker grab yourself a PH00 screwdriver, a metal spudger, and a soldering kit.
- Before you begin disassembling the Vtech InnoTab 3, turn on your soldering iron. If working with others let them know that the soldering iron is on and to use caution.
必要な工具と部品
Slide the battery compartment door lock down.
While still holding the battery compartment lock down, slide the two battery doors outwards on either side of the device.
Carefully remove the batteries from the battery compartment.
After you disassemble the device, put the back panel to the side and move your attention to the front piece.
Remove the four screws using a PH00 screwdriver.
もう少しです!
終わりに
