メインコンテンツにスキップ
Vizio SmartCast Crave 360 Battery Replacement
必要な工具と部品
  1. Vizio SmartCast Crave 360 Battery Replacement, Bottom Panel: 手順 1、 2の画像 1 Vizio SmartCast Crave 360 Battery Replacement, Bottom Panel: 手順 1、 2の画像 2
    • Orient the speaker so that the bottom faces up.
    • Peel the rubber ring off of the bottom using the spudger.
  2. Vizio SmartCast Crave 360 Battery Replacement: 手順 2、 1の画像 1
    • Remove the eight 5 mm screws connecting the bottom panel to the gray power port using a Phillips #000 screwdriver.
  3. Vizio SmartCast Crave 360 Battery Replacement: 手順 3、 2の画像 1 Vizio SmartCast Crave 360 Battery Replacement: 手順 3、 2の画像 2
    • Lift the gray power port and move it to the side to reveal the bass.
    • Do not touch the wire that runs from the power port to the bottom of the bass component.
  4. Vizio SmartCast Crave 360 Battery Replacement, Bass: 手順 4、 2の画像 1 Vizio SmartCast Crave 360 Battery Replacement, Bass: 手順 4、 2の画像 2
    • Remove the collar that wraps around the bass component.
    • Once the collar is removed, the speaker should appear similar to the speaker shown in the second photo.
  5. Vizio SmartCast Crave 360 Battery Replacement: 手順 5、 3の画像 1 Vizio SmartCast Crave 360 Battery Replacement: 手順 5、 3の画像 2 Vizio SmartCast Crave 360 Battery Replacement: 手順 5、 3の画像 3
    • Remove the four 10 mm screws with that connect the bass to the rest of the speaker using a Phillips #000 screwdriver.
    • Take the bass component out of the speaker.
    • Disconnect the wiring that runs into the bass component.
    • The bass is now removed.
  6. Vizio SmartCast Crave 360 Battery Replacement, Battery: 手順 6、 2の画像 1 Vizio SmartCast Crave 360 Battery Replacement, Battery: 手順 6、 2の画像 2
    • Flip the speaker to access the top.
    • Remove the eight 10 mm screws from the plastic disc inside the grey speaker cage using a Phillips #000 screwdriver.
    • Remove the plastic disc from the speaker cage.
  7. Vizio SmartCast Crave 360 Battery Replacement: 手順 7、 1の画像 1
    • Lift the grey speaker cage to reveal a black plastic cylinder that contains the battery.
  8. Vizio SmartCast Crave 360 Battery Replacement: 手順 8、 2の画像 1 Vizio SmartCast Crave 360 Battery Replacement: 手順 8、 2の画像 2
    • Disconnect the wire that connects the motherboard to the battery.
  9. Vizio SmartCast Crave 360 Battery Replacement: 手順 9、 2の画像 1 Vizio SmartCast Crave 360 Battery Replacement: 手順 9、 2の画像 2
    • Remove the motherboard and battery from the plastic cylinder.
  10. Vizio SmartCast Crave 360 Battery Replacement: 手順 10、 1の画像 1
    • Remove the four 5 mm screws from the motherboard using a Phillips #000 screwdriver.
  11. Vizio SmartCast Crave 360 Battery Replacement: 手順 11、 1の画像 1
    • Remove the motherboard from the battery.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Pavani Lopez Leon
メンバー登録日: 09/06/22
427 ポイント
3のガイドは作成済み
チーム
University of Colorado Denver, Team 1-4, Campeau Fall 2022 University of Colorado Denver, Team 1-4, Campeau Fall 2022人のメンバー
UCDENVER-CAMPEAU-F22S1G4
4 メンバー
3のガイドは作成済み
コメント 1 件
Any other way to charge the battery without the charging station or is there a compatible charging station?
Trading Azteca - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 16
過去 30 日: 78
今までの合計 1,128
