メインコンテンツにスキップ
Visual Land Prestige Pro 7D Battery Replacement
必要な工具と部品
  1. Visual Land Prestige Pro 7D Battery Replacement, Back Panel: 手順 1、 1の画像 1
    • Unscrew the two 4.0mm Phillips head screws found near the ports at the bottom of the device using a PH #00 screwdriver.
  2. Visual Land Prestige Pro 7D Battery Replacement: 手順 2、 1の画像 1
    • Be careful when taking the back panel off. The speaker is connected to both the front and back panels, and may get pulled out if you are not gentle when lifting the back panel away.
    • Slide the plastic prying tool in between the front and back panel and pry them apart on all 4 sides.
    • It may be easiest to start on one of the sides, and work your way around the device. The bottom, with the ports, is the most difficult side and can be saved for last.
    • There are small latches that make this difficult. Moderate force may be required to separate the two panels.
  3. Visual Land Prestige Pro 7D Battery Replacement, Battery: 手順 3、 1の画像 1
    • Pry a thin tool under the battery.
    • Be gentle and try not to bend the battery.
    • Slide the tool around all sides of the battery. Separate it evenly on all sides for the best result.
  4. Visual Land Prestige Pro 7D Battery Replacement: 手順 4、 2の画像 1 Visual Land Prestige Pro 7D Battery Replacement: 手順 4、 2の画像 2
    • Soldering guns are hot and can easily damage the device.
    • Desolder the two connections between the red and blue wires where the battery connects to the circuit board.Soldering guns are hot and can easily damage the device.
    • For soldering information, see our guide: はんだ付けとはんだ除去の作業ガイド.
    • If you are removing the LCD display this step is unnecessary.
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Max Hudson
メンバー登録日: 10/14/14
422 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 10-41, Amido Fall 2014 Cal Poly, Team 10-41, Amido Fall 2014人のメンバー
CPSU-AMIDO-F14S10G41
4 メンバー
12のガイドは作成済み
1件のガイドコメント
My tablet shows the icon battery What that mean
paularslay - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 11
今までの合計 6,227
