メインコンテンツにスキップ
Velocity Micro Cruz Speaker Replacement
必要な工具と部品
  1. Velocity Micro Cruz Speaker Replacement, Remove the Back: 手順 1、 1の画像 1
    • Using one of the plastic opening tools, separate the plastic back from the tablet in one spot.
    • Gently work the tool around the diameter of the tablet until the back pops completely off.
  2. Velocity Micro Cruz Speaker Replacement, Remove All Screws: 手順 2、 2の画像 1 Velocity Micro Cruz Speaker Replacement, Remove All Screws: 手順 2、 2の画像 2
    • Use the screwdrivers to remove all the screws.
    • Ensure that all screws are removed before moving on to the next step.
  3. Velocity Micro Cruz Speaker Replacement, Remove LCD Connector: 手順 3、 1の画像 1
    • Remove the bottom LCD connector by gently pulling it away from the motherboard.
  4. Velocity Micro Cruz Speaker Replacement, Separate the Frame from the Housing: 手順 4、 1の画像 1
    • Identify the speaker wires.
    • Use a plastic opening tool to gently pry underneath the frame of the grey plastic frame until it completely separates from the housing.
  5. Velocity Micro Cruz Speaker Replacement, Remove and Replace the Speaker: 手順 5、 1の画像 1
    • Use the wire cutters to clip the speaker wires in the middle
    • Use a plastic opening tool to remove the speaker.
    • Insert the new speaker in its place and solder the old and new wires together.
    • For soldering help, check out iFixit's How to Solder and Desolder Connections guide.
終わりに
作成者
4人の作成者と共同で作成されました。
T Smith
メンバー登録日: 11/02/16
205 ポイント
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 113
