メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
VTech VM3254 Monitor Circuit Board and Screen Replacement
必要な工具と部品
  1. VTech VM3254 Monitor Circuit Board and Screen Replacement, Battery: 手順 1、 2の画像 1 VTech VM3254 Monitor Circuit Board and Screen Replacement, Battery: 手順 1、 2の画像 2
    • Turn the monitor on its back, and remove the two 8 mm Phillips #0 case screws.
    FixBotに聞いてみる
    コメントを追加
  2. VTech VM3254 Monitor Circuit Board and Screen Replacement: 手順 2、 3の画像 1 VTech VM3254 Monitor Circuit Board and Screen Replacement: 手順 2、 3の画像 2 VTech VM3254 Monitor Circuit Board and Screen Replacement: 手順 2、 3の画像 3
    • Use the iFixit Jimmy tool to begin removing the face of the monitor.
    • You may need to use an opening pick to hold the screen open as you move the Jimmy tool around all the edges of the device.
    • Once the screen has been separated, lift it from the case.
    • Be gentle while removing the screen. There are wires connected to the two pieces that may be damaged.
    FixBotに聞いてみる
    コメントを追加
  3. VTech VM3254 Monitor Circuit Board and Screen Replacement: 手順 3、 2の画像 1 VTech VM3254 Monitor Circuit Board and Screen Replacement: 手順 3、 2の画像 2
    • Remove the four 8 mm Phillips #00 screws from the bracket that secures the battery.
    • Remove the bracket.
    FixBotに聞いてみる
    コメントを追加
  4. VTech VM3254 Monitor Circuit Board and Screen Replacement: 手順 4、 3の画像 1 VTech VM3254 Monitor Circuit Board and Screen Replacement: 手順 4、 3の画像 2 VTech VM3254 Monitor Circuit Board and Screen Replacement: 手順 4、 3の画像 3
    • Gently remove the battery from its location.
    • Carefully disconnect the bundled cable connector from the circuit board.
    FixBotに聞いてみる
    コメントを追加
  5. VTech VM3254 Monitor Circuit Board and Screen Replacement, Monitor Speaker: 手順 5、 2の画像 1 VTech VM3254 Monitor Circuit Board and Screen Replacement, Monitor Speaker: 手順 5、 2の画像 2
    • Remove the two 7 mm Phillips #00 screws from the speaker.
    • Carefully remove the speaker and its cords from the motherboard.
    • Handle gently to not break the motherboard or any other parts.
    FixBotに聞いてみる
    コメントを追加
  6. VTech VM3254 Monitor Circuit Board and Screen Replacement: 手順 6、 1の画像 1
    • Desolder the wire connecting the speaker to the board.
    FixBotに聞いてみる
    コメントを追加
  7. VTech VM3254 Monitor Circuit Board and Screen Replacement, Monitor Circuit Board and Screen: 手順 7、 2の画像 1 VTech VM3254 Monitor Circuit Board and Screen Replacement, Monitor Circuit Board and Screen: 手順 7、 2の画像 2
    • Remove the three 8 mm Phillips #00 screws.
    • Gently remove the screen and circuit board from the case.
    FixBotに聞いてみる
    コメントを追加
  8. VTech VM3254 Monitor Circuit Board and Screen Replacement: 手順 8、 2の画像 1 VTech VM3254 Monitor Circuit Board and Screen Replacement: 手順 8、 2の画像 2
    • Remove the button assembly from the front of the screen unit.
    • Flip the screen unit back over and desolder the wire holding it to the case.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
3人の作成者と共同で作成されました。
Christina Block
メンバー登録日: 02/09/23
375 ポイント
4のガイドは作成済み
チーム
Utah Tech University, Team 1-2, McMurrin Spring 2023 Utah Tech University, Team 1-2, McMurrin Spring 2023人のメンバー
UTAHTECH-MCMURRIN-S23S1G2
4 メンバー
6のガイドは作成済み
2件のガイドコメント
Any source for replacement screens?
Rob Olivieri - 返信 共有
Would their be a way to connect the monitor to say a HDMI or VGA cable. To connect to a computer so you could get the video on your computer monitor and possibly be able to record to a hard drive. Just a thought I had. Thank you
Nad Bauch - 返信 共有
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 73
今までの合計 1,978
