メインコンテンツにスキップ
VTech Spin and Learn Color Flashlight Speaker Replacement
必要な工具と部品
  1. VTech Spin and Learn Color Flashlight Speaker Replacement, Battery Housing: 手順 1、 2の画像 1 VTech Spin and Learn Color Flashlight Speaker Replacement, Battery Housing: 手順 1、 2の画像 2
    • Locate the battery housing on the back of the flashlight as pictured.
    • Unscrew the single 8 mm Phillips #1 screw.
    • The screw will stay attached to the cover that will be removed.
    • Lift the battery housing cover to reveal the battery terminals. Remove the batteries.
  2. VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker Housing: 手順 2、 3の画像 1 VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker Housing: 手順 2、 3の画像 2 VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker Housing: 手順 2、 3の画像 3
    • Locate the light blue speaker housing on the bottom of the flashlight.
    • Remove the three 6 mm Phillips #0 screws.
    • Once the screws have been removed, pull the housing away from the yellow body of the flashlight. Be careful not to disconnect the white wires from the speaker, unless speaker replacement is required.
  3. VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker: 手順 3、 3の画像 1 VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker: 手順 3、 3の画像 2 VTech Spin and Learn Color Flashlight Speaker Replacement, Speaker: 手順 3、 3の画像 3
    • Locate the wires connected to the speaker indicated by the red circles in image one.
    • Desolder the wires from the connection point circled in the second image. If you're unsure of how to use the soldering station, use iFixit's guide to soldering and desoldering to help.
    • Remove the 2 highlighted 4mm Phillips #0 screws in image three.
終わりに
作成者
2人の作成者と共同で作成されました。
Nathaniel Troyer
メンバー登録日: 08/27/15
441 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 2-6, Blackwell Fall 2015 USF Tampa, Team 2-6, Blackwell Fall 2015人のメンバー
USFT-BLACKWELL-F15S2G6
3 メンバー
18のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 10
今までの合計 460
