メインコンテンツにスキップ
VTech Little Apps Tablet Battery Internal Wiring Replacement
必要な工具と部品
  1. VTech Little Apps Tablet Battery Internal Wiring Replacement, Battery: 手順 1、 1の画像 1
    • Remove the 9.9 mm screw covering the batteries with a PH1 driver head.
  2. VTech Little Apps Tablet Battery Internal Wiring Replacement: 手順 2、 1の画像 1
    • Use a plastic opening tool to pry the batteries out of their holding.
    • If replacing your batteries with new ones, be careful to insert them as indicated on the device.
  3. VTech Little Apps Tablet Battery Internal Wiring Replacement, Back Cover: 手順 3、 2の画像 1 VTech Little Apps Tablet Battery Internal Wiring Replacement, Back Cover: 手順 3、 2の画像 2
    • Position the VTech Little Apps Tablet face-down on a flat surface so that you can clearly see the back of the device.
    • Remove all seven 9.6 mm screws located around the perimeter of the back cover with a PH1 driver head.
  4. VTech Little Apps Tablet Battery Internal Wiring Replacement: 手順 4、 2の画像 1 VTech Little Apps Tablet Battery Internal Wiring Replacement: 手順 4、 2の画像 2
    • Gently remove the back cover then flip it 180 degrees so that the back cover of the device is now face-down.
    • Proceed with caution as there are wires attaching the back cover to the front cover of the device that could be easily detached.
  5. VTech Little Apps Tablet Battery Internal Wiring Replacement, Battery Internal Wiring: 手順 5、 1の画像 1
    • Visually inspect the wires connecting the motherboard to the batteries, looking for damage.
    • Possible damage includes: lead disconnections, wire fraying, and complete wire disconnections.
  6. VTech Little Apps Tablet Battery Internal Wiring Replacement: 手順 6、 1の画像 1
    • Desolder the internal wire leads connected to the batteries, making sure to remove the positive (red) wire first, and the negative (black) wire second.
    • For assistance with soldering, see this Guide.
  7. VTech Little Apps Tablet Battery Internal Wiring Replacement: 手順 7、 1の画像 1
    • Next desolder the same black and red internal wire leads connected to the motherboard.
    • The order does not matter for this step.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Johnnie Cairns
メンバー登録日: 02/10/16
522 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 2-6, Sullivan Spring 2016 USF Tampa, Team 2-6, Sullivan Spring 2016人のメンバー
USFT-SULLIVAN-S16S2G6
3 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 21
今までの合計 1,384
