このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
Cut the outer cable covering with wire cutters or scissors of both cables and be careful not to cut the wires themselves.
Pull off the piece of cover that you've separated from the rest. You should be left with four exposed individual wires.
If there are more than 4 wires, you probably have a USB 3.0 cable. In this case, make sure that whatever wires you'll be reconnecting are both USB 3.0.
この手順は未翻訳です。 翻訳を手伝う。
Solder like-colored wires to each other.
Here is a video on how to solder wires together. https://www.youtube.com/watch?v=qxqZJH3S...
32 の人々がこのガイドを完成させました。
7 件のコメント
thanks you verb much
very i meant
What if it has a wire shield around it? Like crazy silver wires wrapped around it?
Then slowly wnwrap it not to remove it. And when u have repaired wires and taped them re wrap with silver shielding if it does have shielding it best to add a step to the repair and tbats to add a short section of shrink tubeing just big enough to cover spliced section and shielding. Once shielding is wrapped slid tubeing over repaired section and apply heat a hairdryer on high heat will work as well.
i tried solding the same wires but it still do not work
Faizan Ali - 返信
