メインコンテンツにスキップ
Turtle Beach Ear Force X12 Microphone Replacement
必要な工具と部品
  1. Turtle Beach Ear Force X12 Microphone Replacement, Ear Pads: 手順 1、 1の画像 1
    • Start by removing the left ear pad.
    • Gently pull on the pad from the side by the leathery material until it comes loose from slot.
    • Be careful not to rip the fabric.
  2. Turtle Beach Ear Force X12 Microphone Replacement: 手順 2、 1の画像 1
    • Grip ear cushion and carefully pull up and separate from the plastic headphone.
  3. Turtle Beach Ear Force X12 Microphone Replacement: 手順 3、 2の画像 1 Turtle Beach Ear Force X12 Microphone Replacement: 手順 3、 2の画像 2
    • Your headset should look like the first picture, with the left cushion removed.
    • Repeat these steps for right cushion.
    • You may now continue with more complex inner headset repair, or replace the ear pads by sliding on new ones in the slot.
  4. Turtle Beach Ear Force X12 Microphone Replacement, Microphone: 手順 4、 2の画像 1 Turtle Beach Ear Force X12 Microphone Replacement, Microphone: 手順 4、 2の画像 2
    • Remove the three 1.1 mm screws around the speaker using a T3 screwdriver.
    • Open the top panel carefully.
    • Potential for device damage: The wires are very delicate and can be broken easily.
  5. Turtle Beach Ear Force X12 Microphone Replacement: 手順 5、 2の画像 1 Turtle Beach Ear Force X12 Microphone Replacement: 手順 5、 2の画像 2
    • Remove the 5 mm screw using a Phillips #00 screwdriver.
    • Carefully pull the wire to the side to allow access to the screw if necessary.
  6. Turtle Beach Ear Force X12 Microphone Replacement: 手順 6、 2の画像 1 Turtle Beach Ear Force X12 Microphone Replacement: 手順 6、 2の画像 2
    • Cut the microphone wire with wire cutters.
    • Desolder the microphone wires.
    • Practice caution while soldering. Ensure proper safety and soldering procedure is followed to avoid component damage and injury.
    • For more information on soldering, check out this guide.
  7. Turtle Beach Ear Force X12 Microphone Replacement: 手順 7、 2の画像 1 Turtle Beach Ear Force X12 Microphone Replacement: 手順 7、 2の画像 2
    • Insert the new microphone and solder the wires into the correct positions.
    • Position the speaker on the headset so the screw holes are aligned.
終わりに
作成者
7人の作成者と共同で作成されました。
Maria Fontiveros
メンバー登録日: 10/02/17
101 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team S1-G3, Thompson Fall 2017 USF Tampa, Team S1-G3, Thompson Fall 2017人のメンバー
USFT-THOMPSON-F17S1G3
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 1,926
