メインコンテンツにスキップ
Turtle Beach Ear Force P11 Speakers Replacement
必要な工具と部品
  1. Turtle Beach Ear Force P11 Speakers Replacement, Ear Cushion: 手順 1、 1の画像 1
    • Pinch the inner edge of the ear cushion from the bottom.
  2. Turtle Beach Ear Force P11 Speakers Replacement: 手順 2、 1の画像 1
    • Now slowly pull down the ear cushion as it completely separates from the speaker.
    • Carry out the pulling down action as slowly as possible or you might risk tearing the ear cushion otherwise
  3. Turtle Beach Ear Force P11 Speakers Replacement, Speakers: 手順 3、 1の画像 1
    • Remove the 4 screws on the red speaker cover.
    • It is recommended to use a #000 Philips Screw Driver
  4. Turtle Beach Ear Force P11 Speakers Replacement: 手順 4、 2の画像 1 Turtle Beach Ear Force P11 Speakers Replacement: 手順 4、 2の画像 2
    • Inspect the wires for damage as illustrated
  5. Turtle Beach Ear Force P11 Speakers Replacement: 手順 5、 1の画像 1
    • De-solder the speaker wires and remove the speaker.
    • Use low heat for de - soldering
  6. Turtle Beach Ear Force P11 Speakers Replacement: 手順 6、 1の画像 1
    • Solder the new speaker wires in the same position as the old one.
    • It is advisable to use a lead free solder
    • Use a small amount of solder to not mix up the connections and prevent short circuiting.
    • In case you use a large amount of solder, use a solder wick to absorb the excess solder.
    • You can find more information on "How To Solder" here:はんだ付けとはんだ除去の作業ガイド
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Bhavesh Gandhi
メンバー登録日: 09/26/15
585 ポイント
3のガイドは作成済み
チーム
IUPUI, Team 1-2, Wilson Fall 2015 IUPUI, Team 1-2, Wilson Fall 2015人のメンバー
IUPUI-WILSON-F15S1G2
2 メンバー
6のガイドは作成済み
6 件のコメント
can you fix mine contact me a jtrent238@outlook.com
jtrent238 - 返信
I am sorry jtrent238 , but i can further guide you on how you could solve the problem
Bhavesh Gandhi - 返信
If you look at step four you will see the black wire has a knot and a silver metal part. Well My wire has broken right there any advice? Please help!
Dev - 返信
Do you know where I can get the speakers from?
James Patrick - 返信
my problem exist in this area https://imgur.com/grLwOkt cant figure out how to detach the entire bud to get access to the internal wires
John - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 20
今までの合計 3,682
