はじめに
If the speaker on your Trio Stealth-10 is no longer functioning, replacement isn't difficult and this guide will give you the step by step procedure to do so.
必要な工具と部品
To remove the back panel, you will need to use a plastic opening tool and slowly separate the back panel from the device.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
