メインコンテンツにスキップ
Trio Stealth-10 Motherboard Replacement
必要な工具と部品
  1. Trio Stealth-10 Motherboard Replacement, Back Panel: 手順 1、 1の画像 1
    • To remove the back panel, you will need to use a plastic opening tool and slowly separate the back panel from the device.
  2. Trio Stealth-10 Motherboard Replacement, Speaker: 手順 2、 1の画像 1
    • This next step will require you to solder a couple of wires off the motherboard. We recommend you get someone to help you if you are unfamiliar with soldering or use Ifixit's Soldering guide to help you.
    • Next you must solder off the wires that connect the speaker to the motherboard.
  3. Trio Stealth-10 Motherboard Replacement: 手順 3、 1の画像 1
    • Next you will need to remove the two screws attached to the speaker. If you have a 54 bit Driver Kit use the Philips Head 0 (or PH 0) head to remove the two 4mm screws.
  4. Trio Stealth-10 Motherboard Replacement, Front-Facing/ Rear-Facing Camera: 手順 4、 1の画像 1
    • Next use your PH 0 to remove the two 4mm screws to detach the camera support fixture.
  5. Trio Stealth-10 Motherboard Replacement: 手順 5、 1の画像 1
    • Disconnect the camera from the mother board. Use a spudger and lift the grey latch until it is facing up then pull out the connection for the cameras.
  6. Trio Stealth-10 Motherboard Replacement: 手順 6、 1の画像 1
    • Remove the first layer of tape above camera cable connection slowly.
  7. Trio Stealth-10 Motherboard Replacement: 手順 7、 1の画像 1
    • Remove the second layer of tape above camera cable connection gently and remove the cameras from the device.
  8. Trio Stealth-10 Motherboard Replacement, Battery: 手順 8、 1の画像 1
    • This step will require soldering. If you are unfamiliar with soldering then we recommend that you get help from another person or use the soldering guide made by Ifixit to help.
    • Solder the connections off for the battery.
  9. Trio Stealth-10 Motherboard Replacement: 手順 9、 2の画像 1 Trio Stealth-10 Motherboard Replacement: 手順 9、 2の画像 2
    • Disconnect the screen/digitizer connection. Use tweezers and pull each grey end of the connection until there is a small gap between the grey and white on the connector to the motherboard. The connection should be easily removable.
    • Pull the cable away and clear from under the battery to avoid damage to the connection.
  10. Trio Stealth-10 Motherboard Replacement: 手順 10、 1の画像 1
    • Pry battery up from adhesive. Use a type of adhesive remover. Nail polish remover works well.
  11. Trio Stealth-10 Motherboard Replacement, Motherboard: 手順 11、 1の画像 1
    • Use your spudger to disconnect the screen/digitizer connection from the motherboard.
  12. Trio Stealth-10 Motherboard Replacement: 手順 12、 2の画像 1 Trio Stealth-10 Motherboard Replacement: 手順 12、 2の画像 2
    • Use a pair of tweezers to grasp the screen/digitizer connection gently and remove each accordingly.
  13. Trio Stealth-10 Motherboard Replacement: 手順 13、 1の画像 1
    • Grasp the EDC tape with your tweezers and lift it off gently from the motherboard and set aside to be reused.
  14. Trio Stealth-10 Motherboard Replacement: 手順 14、 2の画像 1 Trio Stealth-10 Motherboard Replacement: 手順 14、 2の画像 2
    • Use a Phillips #0 to unscrew the 4mm screws from the motherboard fixture.
  15. Trio Stealth-10 Motherboard Replacement: 手順 15、 1の画像 1
    • Be sure that all the connections to the motherboard are disconnected. Proceed to remove the motherboard by slowly tilting it away from you and then lifting it straight up.
終わりに
5 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Daniel Coleman
メンバー登録日: 10/29/15
643 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 1-4, Miles Fall 2015 UMass Dartmouth, Team 1-4, Miles Fall 2015人のメンバー
UMASSD-MILES-F15S1G4
3 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 6
今までの合計 1,489
