メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Trio Stealth G4 Battery Replacement
必要な工具と部品
  1. Trio Stealth G4 Battery Replacement, Back Panel: 手順 1、 1の画像 1
    • Working on your device while it is turned on may result in electric shock. Be sure to shut down and unplug your device before you begin.
    • Flip your tablet over so that the back panel is facing up.
    FixBotに聞いてみる
    コメントを追加
  2. Trio Stealth G4 Battery Replacement: 手順 2、 2の画像 1 Trio Stealth G4 Battery Replacement: 手順 2、 2の画像 2
    • Use a plastic opening tool to gently pry the back panel assembly apart from the front casing.
    • Start on one edge of the device by inserting the plastic opening tool between the back panel and the front casing using a gentle rocking motion.
    FixBotに聞いてみる
    コメントを追加
  3. Trio Stealth G4 Battery Replacement: 手順 3、 1の画像 1
    • Once you have successfully separated one edge of the back panel from the front casing, slide the plastic opening tool along the other edges to detach them as well.
    • The latches keeping the back panel attached to the front casing can sometimes be a little difficult to separate, so don't be afraid to use some force.
    FixBotに聞いてみる
    コメントを追加
  4. Trio Stealth G4 Battery Replacement: 手順 4、 2の画像 1 Trio Stealth G4 Battery Replacement: 手順 4、 2の画像 2
    • Remove the back panel from the rest of the tablet and set it aside.
    FixBotに聞いてみる
    コメントを追加
  5. Trio Stealth G4 Battery Replacement: 手順 5、 1の画像 1
    • The plastic volume button cover may fall out when you remove the back panel. Set it aside.
    FixBotに聞いてみる
    コメントを追加
  6. Trio Stealth G4 Battery Replacement, Battery: 手順 6、 1の画像 1
    • Remove the black tape covering the zero insertion force (ZIF) connector that holds down the end of the yellow colored ribbon wire that lies across the battery.
    FixBotに聞いてみる
    コメントを追加
  7. Trio Stealth G4 Battery Replacement: 手順 7、 3の画像 1 Trio Stealth G4 Battery Replacement: 手順 7、 3の画像 2 Trio Stealth G4 Battery Replacement: 手順 7、 3の画像 3
    • Wedge a spudger underneath the black flap on the ZIF connector and flip it up.
    • Once the flap is up, use your fingers to disconnect the end of the ribbon wire from the connector.
    FixBotに聞いてみる
    コメントを追加
  8. Trio Stealth G4 Battery Replacement: 手順 8、 1の画像 1
    • Carefully remove the yellow tape from the red and black wires connecting the battery to the motherboard.
    FixBotに聞いてみる
    コメントを追加
  9. Trio Stealth G4 Battery Replacement: 手順 9、 1の画像 1
    • Use the soldering iron to melt away the solder from the motherboard connections.
    • Once the solder is completely removed, pull the wires away from the motherboard.
    FixBotに聞いてみる
    コメントを追加
  10. Trio Stealth G4 Battery Replacement: 手順 10、 2の画像 1 Trio Stealth G4 Battery Replacement: 手順 10、 2の画像 2
    • Use the spudger to gently dislodge the battery from the tablet.
    • Do not bend the lithium-ion battery. This can cause a fire.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Matt Arnold
メンバー登録日: 09/22/15
607 ポイント
5のガイドは作成済み
チーム
Baylor, Team 4-1, Williams Fall 2015 Baylor, Team 4-1, Williams Fall 2015人のメンバー
BU-WILLIAMS-F15S4G1
4 メンバー
10のガイドは作成済み
1件のガイドコメント
trio stealth g4 10.1 v2 tablet replacement battery what battery is that number , please thank you
jone paul - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 34
今までの合計 5,904
