メインコンテンツにスキップ
Trek 820 Handlebars Replacement
必要な工具と部品
  1. Trek 820 Handlebars Replacement, Handlebar and stem: 手順 1、 2の画像 1 Trek 820 Handlebars Replacement, Handlebar and stem: 手順 1、 2の画像 2
    • Use a 3/16" Allen Wrench to remove the silver cap.
  2. Trek 820 Handlebars Replacement: 手順 2、 1の画像 1
    • Use a 7/32" Allen Wrench to remove the two bolts; 1 and 2. These clamp the stem to the steerer tube of the fork.
  3. Trek 820 Handlebars Replacement: 手順 3、 2の画像 1 Trek 820 Handlebars Replacement: 手順 3、 2の画像 2
    • Remove the handlebar by lifting vertically away from the frame.
    • Be careful to lift up only the handlebars and stem. If you lift up by the frame the headset and fork might come lose.
    Worth noting that the silver top cap that you removed in step 1 controls the preload on the steering bearings. When reassembling, the handlebar stem should be installed loosely on the tube but not tightened until the bearing preload is adjusted with the top cap. Then align the stem with the wheel and tighten the bolts.
    Jeff McLellan - 返信
  4. Trek 820 Handlebars Replacement: 手順 4、 2の画像 1 Trek 820 Handlebars Replacement: 手順 4、 2の画像 2
    • To reassemble, slide the stem with and handlebar on to the steerer tube of the fork carefully.
    • Place silver cap on and tighten the bolt with a 3/16" Allen Wrench. This is done first so that the the headset is compressed between the frame and steerer tube of the fork.
  5. Trek 820 Handlebars Replacement: 手順 5、 1の画像 1
    • By hand you can now adjust the positioning of the stem and handlebar so that is in line with the front wheel of the bike.
    • Tighten the two bolts; [I] and [II] with a 7/32" Allen Wrench . These clamp the stem to the steerer tube of the fork.
    • Make sure that after tightening bolt [II] you go back and make sure you check the tightness of bolt [I] again. Since the bolts are used to clamp, bolt I will usually not be tight enough after tightening bolt [II].
終わりに
作成者
10人の作成者と共同で作成されました。
Kaveh Karimiyanha
メンバー登録日: 09/24/12
813 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 1-1, Propen Fall 2012 Cal Poly, Team 1-1, Propen Fall 2012人のメンバー
CPSU-PROPEN-F12S1G1
5 メンバー
9のガイドは作成済み
1件のガイドコメント
Always do step 2 before step 1. Otherwise you could damage the stem or steerer tube.
mel2 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 28
今までの合計 5,990
