はじめに
- The motherboard of a laptop is a vital piece of your computer, if you find that the performance or functionality of your device is limited, then it may be time for the part to be replaced.
- If you are positive that the motherboard of your Toshiba Tecra z50-a is damaged or causing issues, then it’s time for it to be replaced. Follow this guide to learn how to replace the motherboard of the laptop.
- Before disassembling the laptop, ensure it is powered off and nothing is plugged into the device.
- Remove any rings, bracelets, or any other metal objects from your hands.
必要な工具と部品
Turn off the laptop.
Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
Remove the four 3 mm screws from the heat sink using a Phillips #0 screwdriver.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
