この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
必要な工具と部品
Locate the battery locks on the bottom of the laptop.
Slide the right lock outwards, until it locks into place.
Slide and hold the left lock outwards and hold it in place.
Place device down so the bottom of it is facing you.
Unscrew each screw located in the deep holes found around the bottom of the device as shown.
Now turn the device over so you can see the keyboard. Find the plastic bar located at the top of the keyboard.
Pry this plastic cover off with the use of the plastic opening tools.
Now unscrew the screws that are located under the plastic cover previously removed. After these are gone, remove the keyboard.
ある他の人がこのガイドを完成しました。
