メインコンテンツにスキップ
Toshiba Satellite L305-S5875 Speakers Replacement
必要な工具と部品
  1. Toshiba Satellite L305-S5875 Speakers Replacement, Battery: 手順 1、 1の画像 1
    • Close the laptop lid and flip the laptop over.
    • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
  2. Toshiba Satellite L305-S5875 Speakers Replacement: 手順 2、 3の画像 1 Toshiba Satellite L305-S5875 Speakers Replacement: 手順 2、 3の画像 2 Toshiba Satellite L305-S5875 Speakers Replacement: 手順 2、 3の画像 3
    • Push the release button to the right.
    • Hold the release button to the right and lift the battery out of its housing.
  3. Toshiba Satellite L305-S5875 Speakers Replacement, Keyboard: 手順 3、 3の画像 1 Toshiba Satellite L305-S5875 Speakers Replacement, Keyboard: 手順 3、 3の画像 2 Toshiba Satellite L305-S5875 Speakers Replacement, Keyboard: 手順 3、 3の画像 3
    • Open the laptop so the keyboard is facing you.
    • Using your fingers, remove the thin plastic cover above the keyboard.
    • Potential for device damage: Do not apply too much force when removing the cover piece as it can break.
  4. Toshiba Satellite L305-S5875 Speakers Replacement: 手順 4、 1の画像 1
    • Remove the two 4.8 mm screws from underneath the plastic cover piece using a Phillips #00 screwdriver.
  5. Toshiba Satellite L305-S5875 Speakers Replacement: 手順 5、 2の画像 1 Toshiba Satellite L305-S5875 Speakers Replacement: 手順 5、 2の画像 2
    • Starting at the top, gently raise the keyboard enough to remove it from the socket.
    • Potential for device damage: DO NOT pull out the keyboard after it's out of its socket. The keyboard is connected to the hard drive through a data cable and removing forcefully could damage the cable and laptop.
  6. Toshiba Satellite L305-S5875 Speakers Replacement: 手順 6、 2の画像 1 Toshiba Satellite L305-S5875 Speakers Replacement: 手順 6、 2の画像 2
    • Locate the data cable that is connected to the motherboard.
    • Pull the white ZIF connector towards the screen to remove it.
    • Pull the black ribbon cable away from the screen.
  7. Toshiba Satellite L305-S5875 Speakers Replacement: 手順 7、 1の画像 1
    • With the black ribbon cable now disconnected, remove the keyboard from its housing.
  8. Toshiba Satellite L305-S5875 Speakers Replacement, Speakers: 手順 8、 1の画像 1
    • Close the laptop and flip it over.
    • Remove all the 6.6 mm type-00 Phillips head screws along the perimeter and in the center of the laptop.
  9. Toshiba Satellite L305-S5875 Speakers Replacement: 手順 9、 1の画像 1
    • Remove the three 3.7 mm type-00 Phillips head screws located in the battery compartment.
  10. Toshiba Satellite L305-S5875 Speakers Replacement: 手順 10、 2の画像 1 Toshiba Satellite L305-S5875 Speakers Replacement: 手順 10、 2の画像 2
    • Flip the laptop over and open the screen as far back as it can go.
  11. Toshiba Satellite L305-S5875 Speakers Replacement: 手順 11、 2の画像 1 Toshiba Satellite L305-S5875 Speakers Replacement: 手順 11、 2の画像 2
    • Using your fingers, slide the black ZIF connector out.
    • Once the ZIF connector has been moved, the white ribbon cable can be removed.
  12. Toshiba Satellite L305-S5875 Speakers Replacement: 手順 12、 2の画像 1 Toshiba Satellite L305-S5875 Speakers Replacement: 手順 12、 2の画像 2
    • Using your fingers, remove the white plastic connector located to the right of the ribbon connector.
  13. Toshiba Satellite L305-S5875 Speakers Replacement: 手順 13、 3の画像 1 Toshiba Satellite L305-S5875 Speakers Replacement: 手順 13、 3の画像 2 Toshiba Satellite L305-S5875 Speakers Replacement: 手順 13、 3の画像 3
    • Use the blue plastic opening tool to begin removing the cover.
    • After creating enough space, you can use your hands to completely open the cover.
    • Make sure all the screws have been removed before attempting to open the cover.
  14. Toshiba Satellite L305-S5875 Speakers Replacement: 手順 14、 2の画像 1 Toshiba Satellite L305-S5875 Speakers Replacement: 手順 14、 2の画像 2
    • Put the laptop aside and locate the speakers attached to the cover.
    • Remove the two 3.6 mm type-00 Phillips head screws from each speaker.
終わりに
作成者
10人の作成者と共同で作成されました。
Juan
メンバー登録日: 01/11/13
109 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 20-5, Maness Winter 2013 Cal Poly, Team 20-5, Maness Winter 2013人のメンバー
CPSU-MANESS-W13S20G5
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 18
今までの合計 1,699
