メインコンテンツにスキップ
Torque King Electric RTR RC Monster Truck Steering Servo Replacement
必要な工具と部品
  1. Torque King Electric RTR RC Monster Truck Steering Servo Replacement, Casing: 手順 1、 2の画像 1 Torque King Electric RTR RC Monster Truck Steering Servo Replacement, Casing: 手順 1、 2の画像 2
    • From the top view, remove each of the four pins that hold the casing in place.
  2. Torque King Electric RTR RC Monster Truck Steering Servo Replacement: 手順 2、 1の画像 1
    • Slowly pull the casing up to remove it.
  3. Torque King Electric RTR RC Monster Truck Steering Servo Replacement, Battery: 手順 3、 1の画像 1
    • Beginning at the bottom of the truck, twist the release clip on the casing until the release clip is no longer covering the battery casing.
  4. Torque King Electric RTR RC Monster Truck Steering Servo Replacement: 手順 4、 1の画像 1
    • Next, use a Phillips 00 screwdriver to remove the 8mm screw on the battery casing and remove the battery casing.
  5. Torque King Electric RTR RC Monster Truck Steering Servo Replacement: 手順 5、 1の画像 1
    • Do not skip this step if you are continuing onto the next step, you will risk electric shock.
    • Finally, remove the battery from the white connector by squeezing the clip on the connector while pulling.
  6. Torque King Electric RTR RC Monster Truck Steering Servo Replacement, Steering Servo: 手順 6、 1の画像 1
    • Remove the shell of the truck. Using a Phillips #1 screwdriver, remove the seven 10mm screws highlighted.
  7. Torque King Electric RTR RC Monster Truck Steering Servo Replacement: 手順 7、 2の画像 1 Torque King Electric RTR RC Monster Truck Steering Servo Replacement: 手順 7、 2の画像 2
    • Next, rotate the part that supports the truck casing 180 degrees. Use a Phillips #1 Screwdriver to remove the three highlighted screws.
  8. Torque King Electric RTR RC Monster Truck Steering Servo Replacement: 手順 8、 1の画像 1
    • While lifting the part attaching the bumper to the shell of the truck, remove the shell by lifting it upwards and towards the back end of the truck simultaneuously.
  9. Torque King Electric RTR RC Monster Truck Steering Servo Replacement: 手順 9、 1の画像 1
    • Warning: Do not continue if you skipped the battery removal steps of this guide. If you do, you risk injury by electric shock.
    • Now that the shell is removed, carefully lift the steering servo so that you can begin to detach it from the electronics of the truck.
    • Caution: Do not pull the servo with too much force or too far to avoid damage to the wires.
  10. Torque King Electric RTR RC Monster Truck Steering Servo Replacement: 手順 10、 1の画像 1
    • Make note of the order of the colors of the wire.
    • Desolder the four connections in the box shown. From the view shown and from left to right, the order is red, black, green, and yellow.
  11. Torque King Electric RTR RC Monster Truck Steering Servo Replacement: 手順 11、 1の画像 1
    • Again noting where each color of wire is supposed to connect, desolder these last two connections.
終わりに
作成者
4人の作成者と共同で作成されました。
Thomas White
メンバー登録日: 02/02/15
252 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 6-30, Amido Winter 2015 Cal Poly, Team 6-30, Amido Winter 2015人のメンバー
CPSU-AMIDO-W15S6G30
4 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 10
今までの合計 1,085
