はじめに
This guide requires soldering, a guide for which can be found here.
必要な工具と部品
Beginning at the bottom of the truck, twist the release clip on the casing until the release clip is no longer covering the battery casing.
Remove the shell of the truck. Using a Phillips #1 screwdriver, remove the seven 10mm screws highlighted.
もう少しです!
終わりに
