メインコンテンツにスキップ
Tivax MiTraveler 10Q-8 USB Charging Port Replacement
必要な工具と部品
  1. Tivax MiTraveler 10Q-8 USB Charging Port Replacement, Rear Case: 手順 1、 2の画像 1 Tivax MiTraveler 10Q-8 USB Charging Port Replacement, Rear Case: 手順 1、 2の画像 2
    • With the device face down, slide the charging port cover off on the left side of device.
  2. Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 手順 2、 1の画像 1
    • Locate a Phillips 2.88mm screw at the charging port.
  3. Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 手順 3、 1の画像 1
    • Use a PH000 Philips head screwdriver to remove screw.
    • Remember lefty loosey, righty tighty
  4. Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 手順 4、 1の画像 1
    • To pry the back plate off, use the plastic opening tool between the back plate and front plate; start at the headphone jack.
    • Make sure the lip of the plastic opening tool is face up.
  5. Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 手順 5、 2の画像 1 Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 手順 5、 2の画像 2
    • Move around the device with the plastic opening tool, pushing down to release the back plate from clips.
    • You will hear popping sounds when you work around the device.
  6. Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 手順 6、 2の画像 1 Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 手順 6、 2の画像 2
    • Once you’ve moved around the whole device with the plastic opening tool, the back plate will completely release from the rest of the device.
  7. Tivax MiTraveler 10Q-8 USB Charging Port Replacement, Battery: 手順 7、 1の画像 1
    • The battery rests flat on the inside surface of the tablet. It is a rectangular shape and has blue and yellow tape.
  8. Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 手順 8、 1の画像 1
    • Two wires, one red and one black, which run from the motherboard to the battery, need to be desoldered from the motherboard.
    • Review how to solder here.
  9. Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 手順 9、 2の画像 1 Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 手順 9、 2の画像 2
    • Work the soldering gun on the red wire where it is connected to the motherboard. It should release from the motherboard.
    • Work the soldering gun on the black wire where it is connected to the motherboard. It will release from the motherboard.
  10. Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 手順 10、 3の画像 1 Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 手順 10、 3の画像 2 Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 手順 10、 3の画像 3
    • Once both wires have been desoldered, remove the battery from the device.
  11. Tivax MiTraveler 10Q-8 USB Charging Port Replacement, USB Charging Port: 手順 11、 2の画像 1 Tivax MiTraveler 10Q-8 USB Charging Port Replacement, USB Charging Port: 手順 11、 2の画像 2
    • With the device facing down, the USB charging port can be located on the left side of the device directly on the motherboard. The mini HDMI port will be above the charging port and the micro SD port will be below, with the charging port in the middle of the two.
    • Make sure all power is extinguished by following the steps to remove the battery.
    • The charging port will be soldered down at all four corners; each prong will need to be soldered off.
    • Review How to Solder Here
  12. Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 手順 12、 3の画像 1 Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 手順 12、 3の画像 2 Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 手順 12、 3の画像 3
    • Work the iron on one prong at a time that is soldered to the motherboard. The USB port will release from the motherboard.
  13. Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 手順 13、 3の画像 1 Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 手順 13、 3の画像 2 Tivax MiTraveler 10Q-8 USB Charging Port Replacement: 手順 13、 3の画像 3
    • Repeat steps 2-5 for the soldering of the other 3 prongs.
    • Once all four prongs have been soldered off the USB charging port will remove from the device.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Conor Langenbahn
メンバー登録日: 03/11/15
228 ポイント
2のガイドは作成済み
チーム
Colorado Springs, Team 4-3, Panko Spring 2015 Colorado Springs, Team 4-3, Panko Spring 2015人のメンバー
UCCS-PANKO-S15S4G3
3 メンバー
10のガイドは作成済み
コメント 1 件
You forgot to desolder the leads on the board first, if you don't, the lands on the board can be lifted off and you lose contact to the charge circuit.
da ha - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 358
