メインコンテンツにスキップ
Tivax MiTraveler 10Q-8 Motherboard Replacement
必要な工具と部品
  1. Tivax MiTraveler 10Q-8 Motherboard Replacement, Rear Case: 手順 1、 2の画像 1 Tivax MiTraveler 10Q-8 Motherboard Replacement, Rear Case: 手順 1、 2の画像 2
    • With the device face down, slide the charging port cover off on the left side of device.
  2. Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 2、 1の画像 1
    • Locate a Phillips 2.88mm screw at the charging port.
  3. Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 3、 1の画像 1
    • Use a PH000 Philips head screwdriver to remove screw.
    • Remember lefty loosey, righty tighty
  4. Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 4、 1の画像 1
    • To pry the back plate off, use the plastic opening tool between the back plate and front plate; start at the headphone jack.
    • Make sure the lip of the plastic opening tool is face up.
  5. Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 5、 2の画像 1 Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 5、 2の画像 2
    • Move around the device with the plastic opening tool, pushing down to release the back plate from clips.
    • You will hear popping sounds when you work around the device.
  6. Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 6、 2の画像 1 Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 6、 2の画像 2
    • Once you’ve moved around the whole device with the plastic opening tool, the back plate will completely release from the rest of the device.
  7. Tivax MiTraveler 10Q-8 Motherboard Replacement, Battery: 手順 7、 1の画像 1
    • The battery rests flat on the inside surface of the tablet. It is a rectangular shape and has blue and yellow tape.
  8. Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 8、 1の画像 1
    • Two wires, one red and one black, which run from the motherboard to the battery, need to be desoldered from the motherboard.
    • Review how to solder here.
  9. Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 9、 2の画像 1 Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 9、 2の画像 2
    • Work the soldering gun on the red wire where it is connected to the motherboard. It should release from the motherboard.
    • Work the soldering gun on the black wire where it is connected to the motherboard. It will release from the motherboard.
  10. Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 10、 3の画像 1 Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 10、 3の画像 2 Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 10、 3の画像 3
    • Once both wires have been desoldered, remove the battery from the device.
  11. Tivax MiTraveler 10Q-8 Motherboard Replacement, Speaker: 手順 11、 1の画像 1
    • With the face of the device down, locate the speaker in the upper right corner. The black oval shaped object.
    • Make sure Battery has been removed.
  12. Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 12、 2の画像 1 Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 12、 2の画像 2
    • A Phillips 3.88 mm screw holds the speaker in place.
    • Use a PH000 screwdriver to remove the screw.
  13. Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 13、 2の画像 1 Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 13、 2の画像 2
    • The speaker will be connected to two wires; one black and one red. Both run to the motherboard.
    • The wires will need to be soldered off the motherboard.
    • Locate where both wires are soldered to the motherboard.
    • Review How to Solder Here
  14. Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 14、 2の画像 1 Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 14、 2の画像 2
    • Work the iron where the red wire is soldered
    • The wire will release from the motherboard.
  15. Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 15、 3の画像 1 Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 15、 3の画像 2 Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 15、 3の画像 3
    • Work the iron where the black wire is soldered.
    • The black wire will release from the motherboard.
    • After both wires have been soldered off, the speaker will release from the device.
  16. Tivax MiTraveler 10Q-8 Motherboard Replacement, Motherboard: 手順 16、 2の画像 1 Tivax MiTraveler 10Q-8 Motherboard Replacement, Motherboard: 手順 16、 2の画像 2
    • To remove the black ribbon connector, flip the black portion of the connector upward.
    • Pull on the ribbon to remove from the connector.
    • Make sure battery has been removed.
  17. Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 17、 2の画像 1 Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 17、 2の画像 2
    • Remove the white ribbon connector from the motherboard.
  18. Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 18、 2の画像 1 Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 18、 2の画像 2
    • Remove the orange ribbon connector from the motherboard.
  19. Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 19、 2の画像 1 Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 19、 2の画像 2
    • Locate a 2.88 mm Phillips head screw in the upper right hand corner of the mother board.
    • Use a #00 screw driver with the PH000 screw head to remove the screw.
  20. Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 20、 2の画像 1 Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 20、 2の画像 2
    • Locate a 2.88 mm Phillips head screw on the lower left hand corner.
    • Use the #00 screw driver with the PH000 screw head to remove the screw.
  21. Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 21、 2の画像 1 Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 21、 2の画像 2
    • Locate a strip of gold tape, which holds it to the device, on the bottom of the motherboard.
  22. Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 22、 2の画像 1 Tivax MiTraveler 10Q-8 Motherboard Replacement: 手順 22、 2の画像 2
    • On the upper right hand corner of the device, a black wire connects to the device and runs to a strip of orange tape.
    • Remove the tape that holds the wire down.
    • Remove the motherboard from the device.
終わりに
作成者
8人の作成者と共同で作成されました。
Conor Langenbahn
メンバー登録日: 03/11/15
228 ポイント
2のガイドは作成済み
チーム
Colorado Springs, Team 4-3, Panko Spring 2015 Colorado Springs, Team 4-3, Panko Spring 2015人のメンバー
UCCS-PANKO-S15S4G3
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 12
今までの合計 324
