メインコンテンツにスキップ
ThinkVision LT2452p Front panel button caps Fix
必要な工具と部品
  1. ThinkVision LT2452p Front panel button caps Fix, Removing the stand: 手順 1、 2の画像 1 ThinkVision LT2452p Front panel button caps Fix, Removing the stand: 手順 1、 2の画像 2
    • With a PH2 screwdriver, remove the 4 screws (.3" 7.7mm black), and remove the stand.
  2. ThinkVision LT2452p Front panel button caps Fix, Removing the back cover screws: 手順 2、 3の画像 1 ThinkVision LT2452p Front panel button caps Fix, Removing the back cover screws: 手順 2、 3の画像 2 ThinkVision LT2452p Front panel button caps Fix, Removing the back cover screws: 手順 2、 3の画像 3
    • Locate the 2 scews and their cover at the bottom of the back cover.
    • With a sharp object like a spudger, remove the 2 screw caps
    • With a PH2 screwdriver, remove the 2 screws (.38" 9.7mm black).
  3. ThinkVision LT2452p Front panel button caps Fix, Unclipping the back panel: 手順 3、 3の画像 1 ThinkVision LT2452p Front panel button caps Fix, Unclipping the back panel: 手順 3、 3の画像 2 ThinkVision LT2452p Front panel button caps Fix, Unclipping the back panel: 手順 3、 3の画像 3
    • Use the opening tool and pick to undo all the clips around the case, by pulling the border outward.
  4. ThinkVision LT2452p Front panel button caps Fix, Removing the back panel: 手順 4、 2の画像 1 ThinkVision LT2452p Front panel button caps Fix, Removing the back panel: 手順 4、 2の画像 2
    • Before removing the back panel completely you might have to push the bottom USB connector shell inside gently to free the case.
  5. ThinkVision LT2452p Front panel button caps Fix, Removing the front panel button PCB: 手順 5、 2の画像 1 ThinkVision LT2452p Front panel button caps Fix, Removing the front panel button PCB: 手順 5、 2の画像 2
    • Using a PH1 screwdriver, remove the two screws (0.3" 7.6mm silver) holding the front panel PCB.
  6. ThinkVision LT2452p Front panel button caps Fix, Separating the front bezel from the panel assembly: 手順 6、 1の画像 1
    • Carefully flip the panel assembly on the back.
    • You should be able to remove the front bezel easily to work on it. Some button caps might actually fall off of it if they are broken.
  7. ThinkVision LT2452p Front panel button caps Fix, Preparing the front panel button cover fix: 手順 7、 3の画像 1 ThinkVision LT2452p Front panel button caps Fix, Preparing the front panel button cover fix: 手順 7、 3の画像 2 ThinkVision LT2452p Front panel button caps Fix, Preparing the front panel button cover fix: 手順 7、 3の画像 3
    • Remove all broken button caps. You might want to completely break those with a partially broken stem using an sharp blade.
    • Clean the button caps, and the parts which will have to be glued back using isopropyl alcohol.
    • Find something to put under the front bezel so the buttons caps won't be pressed back up when gluing them.
    • Cut 5 pieces from a light cardboard box, 5mm x 15mm, and fold them in a U shape. These will help holding the button caps and keep them centered in place.
    • Cut a dozen pieces about 1mm x 4mm from a pill blister or some other PVC blister. These will be used to reinforce the part we glue back.
  8. ThinkVision LT2452p Front panel button caps Fix, Gluing back the front panel button caps: 手順 8、 3の画像 1 ThinkVision LT2452p Front panel button caps Fix, Gluing back the front panel button caps: 手順 8、 3の画像 2 ThinkVision LT2452p Front panel button caps Fix, Gluing back the front panel button caps: 手順 8、 3の画像 3
    • Put some acetone based glue (like UHU Plast), one drop on each broken stem.
    • Place one of the U-shaped cardboard piece in the button cap hole, and push the cap inside until it is correctly held in place.
    • Make sure each stem is correctly back in place both horizontally and vertically.
    • Repeat for each button cap.
    • Let the glue dry (up to 24 hours).
  9. ThinkVision LT2452p Front panel button caps Fix, Reinforcing the button caps: 手順 9、 2の画像 1 ThinkVision LT2452p Front panel button caps Fix, Reinforcing the button caps: 手順 9、 2の画像 2
    • Place a drop of the same glue over each place that was glued back, and put one of the blister pieces we cut. If you used the aluminum coated part of the blister, make sure the aluminum is on the outside, not facing the glue.
    • You may need to also do this on the other end of the stems for some buttons if you notice they show sign of wear.
    • Let it dry (up to 24 hours).
    • Put it all back in reverse order.
    • Remove the cardboard pieces holding the button caps.
終わりに
If one of the two back panel screw covers doesn't fit flush, remove it, loosen the screw and re-tighten it while holding the back cover in alignment with the front bezel so the screw is centered, and retry putting the cover back.
作成者
1人の作成者と共同作成されました。
mmu_man
メンバー登録日: 04/05/22
174 ポイント
1ガイドが承認済み
1件のガイドコメント
I'm starting to have issues with a LT2323p where the Brightness menu keeps popping up and I guess being stuck randomly at times for over 15 seconds locking the menu as another popup OSD'd. When I first got the monitor, second hand, the power button wasn't performing always to power on. So guessing time to disassemble and see if cleaning alone with resolve? What are your thoughts?
James Finch - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 20
今までの合計 431
