メインコンテンツにスキップ
The Sharper Image Literati Tablet SD Port Replacement
必要な工具と部品
  1. The Sharper Image Literati Tablet SD Port Replacement, Battery: 手順 1、 1の画像 1
    • Wedge plastic spudger tool between the back panel and the body of device.
    • Pry apart the back panel and the device.
  2. The Sharper Image Literati Tablet SD Port Replacement: 手順 2、 1の画像 1
    • Desolder the battery wires from the circuit board.
  3. The Sharper Image Literati Tablet SD Port Replacement: 手順 3、 1の画像 1
    • Warm the battery with a hair dryer.
    • Be carful not to over-heat the battery, this could cause the battery to ignite.
  4. The Sharper Image Literati Tablet SD Port Replacement: 手順 4、 1の画像 1
    この手順で使用する道具:
    Plastic Cards
    $2.99
    購入する
    • Gently wedge a spudger or thin plastic card between the battery and the body of device. Work the spudger or card along the length of the battery to free it from the adhesive.
    • Do not bend or puncture the battery. Work slowly and carefully.
  5. The Sharper Image Literati Tablet SD Port Replacement, SD Port: 手順 5、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the fifteen 4mm screws from the silver peripheral edging.
  6. The Sharper Image Literati Tablet SD Port Replacement: 手順 6、 1の画像 1
    • Use a Phillips #00 screwdriver to remove three 4 mm screws from the circuit board containing the headphone jack and power jack.
  7. The Sharper Image Literati Tablet SD Port Replacement: 手順 7、 1の画像 1
    • Remove the circuit board.
  8. The Sharper Image Literati Tablet SD Port Replacement: 手順 8、 1の画像 1
    • Unclip ZIF clip from the chip and unplug ribbon cable.
  9. The Sharper Image Literati Tablet SD Port Replacement: 手順 9、 1の画像 1
    • Detach the peripheral edge with plastic wedge.
    • This may require a little hard pulling.
  10. The Sharper Image Literati Tablet SD Port Replacement: 手順 10、 1の画像 1
    • Remove peripheral silver edge.
  11. The Sharper Image Literati Tablet SD Port Replacement: 手順 11、 1の画像 1
    • Remove screws from the large metal shielding.
  12. The Sharper Image Literati Tablet SD Port Replacement: 手順 12、 1の画像 1
    • Remove the silver backing plate and the adhered SD port chip.
終わりに
作成者
2人の作成者と共同で作成されました。
Spencer Dodder
メンバー登録日: 03/21/18
560 ポイント
4のガイドは作成済み
チーム
IUPUI, Team S5-G4, Baechle Spring 2018 IUPUI, Team S5-G4, Baechle Spring 2018人のメンバー
IUPUI-BAECHLE-S18S5G4
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 9
今までの合計 243
