メインコンテンツにスキップ
Tapwave T2907US Zodiac 2 Auxiliary Port Replacement
必要な工具と部品
  1. Tapwave T2907US Zodiac 2 Auxiliary Port Replacement, Back Cover: 手順 1、 1の画像 1
    • Remove the four Torx T5 screws from the back panel.
  2. Tapwave T2907US Zodiac 2 Auxiliary Port Replacement: 手順 2、 1の画像 1
    • Wedge a spudger in between the front and back panel.
    • Apply leverage downwards to the spudger in order to remove the back panel.
  3. Tapwave T2907US Zodiac 2 Auxiliary Port Replacement, Battery: 手順 3、 1の画像 1
    • Slide the battery out from under the brown wire-tape.
    • Be careful of the wires still connected to the other end of the battery. Do not pull or damage may occur.
  4. Tapwave T2907US Zodiac 2 Auxiliary Port Replacement: 手順 4、 1の画像 1
    • Slowly pull the white plug from its receptor. Grasp its sides firmly with a pair of tweezers and gently wiggle from side to side.
  5. Tapwave T2907US Zodiac 2 Auxiliary Port Replacement, Motherboard: 手順 5、 1の画像 1
    • Unscrew the 2 Philips #00 screws on each end of the motherboard.
  6. Tapwave T2907US Zodiac 2 Auxiliary Port Replacement: 手順 6、 1の画像 1
    • Pull off the black memory card slot piece with tweezers.
  7. Tapwave T2907US Zodiac 2 Auxiliary Port Replacement: 手順 7、 1の画像 1
    • Unscrew the 2 Philips #00 screws on each side of the charging port.
  8. Tapwave T2907US Zodiac 2 Auxiliary Port Replacement: 手順 8、 2の画像 1 Tapwave T2907US Zodiac 2 Auxiliary Port Replacement: 手順 8、 2の画像 2
    • Disconnect 2 brown wire-tape ends from each end of the motherboard. Gently pull straight out with tweezers.
  9. Tapwave T2907US Zodiac 2 Auxiliary Port Replacement: 手順 9、 1の画像 1
    • Pull the motherboard and screen component diagonally up and left away from the auxiliary port entrance to remove.
    • Glue connecting the auxiliary port to the casing may make it difficult to remove. Gently apply force as needed.
  10. Tapwave T2907US Zodiac 2 Auxiliary Port Replacement: 手順 10、 1の画像 1
    • Disconnect the 2 brown wire-tape ends from the left side of the battery slot on the motherboard using tweezers.
  11. Tapwave T2907US Zodiac 2 Auxiliary Port Replacement: 手順 11、 3の画像 1 Tapwave T2907US Zodiac 2 Auxiliary Port Replacement: 手順 11、 3の画像 2 Tapwave T2907US Zodiac 2 Auxiliary Port Replacement: 手順 11、 3の画像 3
    • Disconnect the large brown wire-tape from the motherboard.
    • Peel the black tape back from the wire-tape using tweezers.
    • Lift the black, hinged, plastic lock with tweezers to release the wire-tape.
    • The screen and motherboard components can now be separated from each other.
  12. Tapwave T2907US Zodiac 2 Auxiliary Port Replacement, Auxiliary Port: 手順 12、 1の画像 1
    この手順で使用する道具:
    Desoldering Pump
    $3.99
    購入する
    • Remove the solder between the auxiliary port and the motherboard carefully with the desoldering pump.
    • Try to avoid contact between the solder sucker and other components surrounding the auxiliary port.
    • Do not get too close to the soldering tip to avoid burn when soldering the new auxiliary port.
    • If you need further aid in desoldering/soldering the auxiliary port follow this guide on soldering components of devices.
終わりに
作成者
5人の作成者と共同で作成されました。
Irvin Camacho
メンバー登録日: 01/26/12
13 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 10-33, Amido Winter 2012 Cal Poly, Team 10-33, Amido Winter 2012人のメンバー
CPSU-AMIDO-W12S10G33
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 6
今までの合計 630
