はじめに
修理前に壊れたiPhoneのディスプレイ表面に透明テープを貼る方法です。
必要な工具と部品
ディスプレイのガラスが割れている場合、作業中さらにダメージが広がったり、作業中、怪我をしないようガラスの表面にテープを貼ります。
透明な粘着テープをiPhoneディスプレイ表面上に二重に装着します。
次のひび割れたガラスのため、次の手順で吸盤カップを引き上げれない場合は、ダクトテープのような強力な粘着テープを使ってハンドルを作り引き上げてください。
もう少しです!
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
終わりに
8 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
翻訳を始める ›
Tape doesn’t hold. suction cup doesn’t work. Tape folded over doesn’t work as a handle. I’ve used 3m’ s Gorilla duct tape. The glass is so shattered I cant get a point started to remove the glass. Phone has been in an otter box for years. dropped it and shattered glass while replacing case. Now what?
Martin Speedy - 返信
When all else fails, you can superglue your suction cup (or tape) to the display, wait for it to cure, and pull.
Jeff Suovanen -
I had issues getting the suction cup to stick on my cracked screen, so I tried using scotch tape (only tape I had around), but it didn’t work. This best thing I did was to forcefully pry the screen off (I wasn’t worried about damages because it’s already cracked) with the spudger. I think its best to find something stickier (like Duct Tape) and used that to lift up the screen.
Definitely surprised how sticky the adhesive was.
Jeffrey Robinos - 返信
When using packing tape: the suction won’t hold well with the overlapping pieces, so add a square of tape where you want to put the suction cup, so it will provide an unbroken surface for the seal.
Christa - 返信
It’s amazing how a heat gun or hair dryer makes life easier to soften up the adhesive. Then use a thin iSesame opening tool to get in under the screen (start @ 90 degrees/vertical either side of the home button & slowly go horizontal) the need to use suction cups. Run the opening tool along the front and down both sides to cut the adhesive before trying to lift the screen.
Cheers Wayne
Wayne Lyell - 返信
I didn’t have a hair dryer so I (gingerly) used an iron over some wet coffee filters (I mean , it is waterproof) . Then, quickly dried i off with paper towels, used gorilla tape and my fixit metal splunger . worked like a charm .
MajorCouillon - 返信
What about baby cracks? skip to step 3 or not…
Andruw Holland - 返信
As others have mentioned, suction cup and tape doesn’t work. I used the blade of a box cutter (watch fingers) and inserted just below and right of home button. Then moved spudger along the crack to tear adhesive/seal. Easy peasy.
Stephen Smith - 返信
