はじめに
Replace the aux port on your device
必要な工具と部品
To remove the front grate of the speaker grab a metal spudger and go to the back corner of the device where the front panel curves around the device. Insert the spudger and ply apart the corner until clips release from panel. Repeat for the other side of the grate. When all clips are released pull grate off from the front of device
Remove the aux port from the board by un-soldering the connection points.
To reattach, solder aux port back onto board. For soldering help, check out iFixit's How to Solder and Desolder Connections guide.
2 の人々がこのガイドを完成させました。
コメント 1 件
I wanted to completely disassemble the speaker to see if I could modify its power source (from battery to USB). but found it glued shut. There are screws that would seem to open up the internals, but removing the screws did nothing. In the end I put it back together, and decided to not replace any of the screws. The glue and metal case are sufficient. No screws necessary.
I would prefer it to not power down while using USB power, but destroying the speaker to convert it to USB power is not the answer.
