メインコンテンツにスキップ
TaoTronics TT-SK06 Aux Port Replacement
必要な工具と部品
  1. TaoTronics TT-SK06 Aux Port Replacement, Front Grate: 手順 1、 2の画像 1 TaoTronics TT-SK06 Aux Port Replacement, Front Grate: 手順 1、 2の画像 2
    • To remove the front grate of the speaker grab a metal spudger and go to the back corner of the device where the front panel curves around the device. Insert the spudger and ply apart the corner until clips release from panel. Repeat for the other side of the grate. When all clips are released pull grate off from the front of device
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
  2. TaoTronics TT-SK06 Aux Port Replacement: 手順 2、 3の画像 1 TaoTronics TT-SK06 Aux Port Replacement: 手順 2、 3の画像 2 TaoTronics TT-SK06 Aux Port Replacement: 手順 2、 3の画像 3
    • Grab two metal spudgers and insert one into the slit underneath the silver plating on the top of the device. Pry upward with the spudger until you unhook the two locks on the top. Repeat same step for the bottom of the device. When all four tabs are released, slide device out of the casing
    • Use caution when working with the metal spudger, as it can potentially damage your device.
  3. TaoTronics TT-SK06 Aux Port Replacement, Aux Port: 手順 3、 1の画像 1
    この手順で使用する道具:
    購入する
    • Remove the circuit board containing the aux port using the tweezers.
  4. TaoTronics TT-SK06 Aux Port Replacement: 手順 4、 1の画像 1
    • Remove the aux port from the board by un-soldering the connection points.
    • To reattach, solder aux port back onto board. For soldering help, check out iFixit's How to Solder and Desolder Connections guide.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Niko Fabian
メンバー登録日: 03/06/16
715 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 5-7, Landers Spring 2016 UMass Dartmouth, Team 5-7, Landers Spring 2016人のメンバー
UMASSD-LANDERS-S16S5G7
3 メンバー
5のガイドは作成済み
コメント 1 件
I wanted to completely disassemble the speaker to see if I could modify its power source (from battery to USB). but found it glued shut. There are screws that would seem to open up the internals, but removing the screws did nothing. In the end I put it back together, and decided to not replace any of the screws. The glue and metal case are sufficient. No screws necessary.
I would prefer it to not power down while using USB power, but destroying the speaker to convert it to USB power is not the answer.
Michael Johnstone - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 1,789
