メインコンテンツにスキップ
Tagital T7X Screen/ Digitizer Replacement
必要な工具と部品
  1. Tagital T7X Screen/ Digitizer Replacement, Case: 手順 1、 3の画像 1 Tagital T7X Screen/ Digitizer Replacement, Case: 手順 1、 3の画像 2 Tagital T7X Screen/ Digitizer Replacement, Case: 手順 1、 3の画像 3
    • Place the Tagital T7X on a sturdy surface.
    • Insert the plastic opening tool into the crack and pry open the tablet. Move the tool along the edge, while continuing to pry up the casing.
  2. Tagital T7X Screen/ Digitizer Replacement, Battery: 手順 2、 2の画像 1 Tagital T7X Screen/ Digitizer Replacement, Battery: 手順 2、 2の画像 2
    • Follow the attached wires to the positive and negative connections.
  3. Tagital T7X Screen/ Digitizer Replacement: 手順 3、 3の画像 1 Tagital T7X Screen/ Digitizer Replacement: 手順 3、 3の画像 2 Tagital T7X Screen/ Digitizer Replacement: 手順 3、 3の画像 3
    • The soldering iron can destroy components on the motherboard. Only touch the soldering iron to the solder already on the board.
    • Touch the tip of the soldering iron to the solder connecting the negative wire.
    • Pull back on the wire with the iron in place, removing it from the hot solder.
    • The solder will be melted almost instantly. There is no need to hold the iron on the solder for more than a second or two. Visit iFixit's soldering guide for more info.
    • Repeat this step for the positive wire.
  4. Tagital T7X Screen/ Digitizer Replacement: 手順 4、 3の画像 1 Tagital T7X Screen/ Digitizer Replacement: 手順 4、 3の画像 2 Tagital T7X Screen/ Digitizer Replacement: 手順 4、 3の画像 3
    • Use the nylon spudger to pry the battery from the back of the screen. Work your way around the edges, similar to opening the casing.
    • The adhesive used to hold the battery down is very strong. Don't be afraid to use some force.
  5. Tagital T7X Screen/ Digitizer Replacement, Speaker: 手順 5、 3の画像 1 Tagital T7X Screen/ Digitizer Replacement, Speaker: 手順 5、 3の画像 2 Tagital T7X Screen/ Digitizer Replacement, Speaker: 手順 5、 3の画像 3
    • Remove the ribbon cable on the top left corner of the mother board.
    • Gently lift the black tape up to see the ribbon cable socket.
  6. Tagital T7X Screen/ Digitizer Replacement: 手順 6、 3の画像 1 Tagital T7X Screen/ Digitizer Replacement: 手順 6、 3の画像 2 Tagital T7X Screen/ Digitizer Replacement: 手順 6、 3の画像 3
    • Push both side buttons away from the socket by using a spudger.
  7. Tagital T7X Screen/ Digitizer Replacement: 手順 7、 2の画像 1 Tagital T7X Screen/ Digitizer Replacement: 手順 7、 2の画像 2
    • Gently pull the ribbon cable away from the socket.
    • Don't be afraid to use some force for this step.
  8. Tagital T7X Screen/ Digitizer Replacement: 手順 8、 2の画像 1 Tagital T7X Screen/ Digitizer Replacement: 手順 8、 2の画像 2
    • Touch the tip of the soldering iron to the solder connecting the positive (red) wire.
    • Repeat this step for the negative wire.
    • The solder will be melted almost instantly. There is no need to hold the iron on the solder for than a second or two. Visit IFixit's soldering guide for more info.
  9. Tagital T7X Screen/ Digitizer Replacement: 手順 9、 2の画像 1 Tagital T7X Screen/ Digitizer Replacement: 手順 9、 2の画像 2
    • Remove the speaker from the motherboard.
  10. Tagital T7X Screen/ Digitizer Replacement, Camera: 手順 10、 3の画像 1 Tagital T7X Screen/ Digitizer Replacement, Camera: 手順 10、 3の画像 2 Tagital T7X Screen/ Digitizer Replacement, Camera: 手順 10、 3の画像 3
    • Use a spudger to hold the cameras in place.
    • Gently pull the black tape away using your finger.
  11. Tagital T7X Screen/ Digitizer Replacement: 手順 11、 3の画像 1 Tagital T7X Screen/ Digitizer Replacement: 手順 11、 3の画像 2 Tagital T7X Screen/ Digitizer Replacement: 手順 11、 3の画像 3
    • Remove the ribbon cable from the motherboard.
    • Use a spudger to lift the two tabs, freeing the ribbon cable from the socket.
  12. Tagital T7X Screen/ Digitizer Replacement: 手順 12、 3の画像 1 Tagital T7X Screen/ Digitizer Replacement: 手順 12、 3の画像 2 Tagital T7X Screen/ Digitizer Replacement: 手順 12、 3の画像 3
    • Gently pull the ribbon cable away from the motherboard.
    • Don't be afraid to use some force to pull the ribbon cable.
  13. Tagital T7X Screen/ Digitizer Replacement, Motherboard: 手順 13、 2の画像 1 Tagital T7X Screen/ Digitizer Replacement, Motherboard: 手順 13、 2の画像 2
    • Next we will disconnect the digitizer ribbon cable from the motherboard.
    • Using the black spudger, gently push the tabs on each side of the socket to free the ribbon cable.
  14. Tagital T7X Screen/ Digitizer Replacement: 手順 14、 2の画像 1 Tagital T7X Screen/ Digitizer Replacement: 手順 14、 2の画像 2
    • Gently pull on the ribbon cable, separating it from the socket.
  15. Tagital T7X Screen/ Digitizer Replacement: 手順 15、 3の画像 1 Tagital T7X Screen/ Digitizer Replacement: 手順 15、 3の画像 2 Tagital T7X Screen/ Digitizer Replacement: 手順 15、 3の画像 3
    • Next, we will unscrew the three PH#0 screws anchoring the motherboard into the case.
    • You will need the Phillips Screw #0 to remove the screws of the motherboard.
    • Using the screwdriver, with the PH#0 attachment, carefully unscrew the screws of the motherboard in order to remove it from the device.
  16. Tagital T7X Screen/ Digitizer Replacement, Screen/ Digitizer: 手順 16、 3の画像 1 Tagital T7X Screen/ Digitizer Replacement, Screen/ Digitizer: 手順 16、 3の画像 2 Tagital T7X Screen/ Digitizer Replacement, Screen/ Digitizer: 手順 16、 3の画像 3
    • Insert a plastic opening tool where the screen connects with the front face of the case.
    • Use a spudger to keep the screen from falling back into the casing.
    • The screen will slide out once the connection has been nudged on three sides.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Garven Dabady
メンバー登録日: 02/10/16
370 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 2-1, Sullivan Spring 2016 USF Tampa, Team 2-1, Sullivan Spring 2016人のメンバー
USFT-SULLIVAN-S16S2G1
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 12
今までの合計 684
