メインコンテンツにスキップ
Tagital T7X Battery Replacement
必要な工具と部品
  1. Tagital T7X Battery Replacement, Case: 手順 1、 3の画像 1 Tagital T7X Battery Replacement, Case: 手順 1、 3の画像 2 Tagital T7X Battery Replacement, Case: 手順 1、 3の画像 3
    • Place the Tagital T7X on a sturdy surface.
    • Insert the plastic opening tool into the crack and pry open the tablet. Move the tool along the edge, while continuing to pry up the casing.
  2. Tagital T7X Battery Replacement, Battery: 手順 2、 2の画像 1 Tagital T7X Battery Replacement, Battery: 手順 2、 2の画像 2
    • Follow the attached wires to the positive and negative connections.
  3. Tagital T7X Battery Replacement: 手順 3、 3の画像 1 Tagital T7X Battery Replacement: 手順 3、 3の画像 2 Tagital T7X Battery Replacement: 手順 3、 3の画像 3
    • The soldering iron can destroy components on the motherboard. Only touch the soldering iron to the solder already on the board.
    • Touch the tip of the soldering iron to the solder connecting the negative wire.
    • Pull back on the wire with the iron in place, removing it from the hot solder.
    • The solder will be melted almost instantly. There is no need to hold the iron on the solder for more than a second or two. Visit iFixit's soldering guide for more info.
    • Repeat this step for the positive wire.
  4. Tagital T7X Battery Replacement: 手順 4、 3の画像 1 Tagital T7X Battery Replacement: 手順 4、 3の画像 2 Tagital T7X Battery Replacement: 手順 4、 3の画像 3
    • Use the nylon spudger to pry the battery from the back of the screen. Work your way around the edges, similar to opening the casing.
    • The adhesive used to hold the battery down is very strong. Don't be afraid to use some force.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Kevin Dennis
メンバー登録日: 02/10/16
184 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 2-1, Sullivan Spring 2016 USF Tampa, Team 2-1, Sullivan Spring 2016人のメンバー
USFT-SULLIVAN-S16S2G1
4 メンバー
12のガイドは作成済み
コメント 1 件
We're can I get a battery? And I don't think the part should have died in less than a year . The battery lasted less than 6 mos. I bought the tablet for my mom to play cards on and that's it .She doesn't go on line. I put a book on it before I gave it to her and that is it. She doesn't even use it every day . What's the deal?
Melanie Bouy - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 1,026
