メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
TI-Nspire CX Battery Replacement
必要な工具と部品
  1. TI-Nspire CX Battery Replacement, Battery: 手順 1、 1の画像 1
    • Use a Phillips #0 screwdriver to loosen the captive screws on the back plate of the calculator.
    • The screws do not come all the way out. Simply twist them until you are able to remove the back plate.
  2. TI-Nspire CX Battery Replacement: 手順 2、 2の画像 1 TI-Nspire CX Battery Replacement: 手順 2、 2の画像 2
    • Remove the back plate using the spudger or by hand.
  3. TI-Nspire CX Battery Replacement: 手順 3、 3の画像 1 TI-Nspire CX Battery Replacement: 手順 3、 3の画像 2 TI-Nspire CX Battery Replacement: 手順 3、 3の画像 3
    • Carefully disconnect and remove the old battery.
    • Unhook the wire from the tab.
    • Carefully pull out the connector.
    • Grip the wire close to the top and pull away.
  4. TI-Nspire CX Battery Replacement: 手順 4、 1の画像 1
    • Plug in the new battery.
    • Make sure to put the wire back in the same way. You should see 4 metal connections on top
  5. TI-Nspire CX Battery Replacement: 手順 5、 1の画像 1
    • Position the new battery and tuck the wire under the tab.
  6. TI-Nspire CX Battery Replacement: 手順 6、 1の画像 1
    • Replace the back plate and the 2 screws.
終わりに
Now charge your calculator and power it up. If replacing the battery does not solve your problem, it may be a problem with your charging cord or the internal sockets.
11 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Jim Kerman
メンバー登録日: 02/24/15
356 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 24-2, Green Winter 2015 Cal Poly, Team 24-2, Green Winter 2015人のメンバー
CPSU-GREEN-W15S24G2
4 メンバー
4のガイドは作成済み
2件のガイドコメント
Hi. I own a TI Nspire CX CAS. I’ve had it for 5 years now and the battery’s been screwy for the past few years. I just ordered a new battery with good reviews from amazon. I’m worried that if I take out the battery my documents and other saved settings will be deleted. Does removing the battery delete anything? I have the modded operating system for my oldschool gameboy games, so I really don’t want to lose my games and settings, as the laptop I used years ago to put the games on there has been broken. I would really appreciate any help. Thank you.
G Reod - 返信 共有
Hola Amigo. Pudiste solucionar?
Armando02 - 共有
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 35
過去 30 日: 116
今までの合計 19,307
