メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
TI-Nspire Battery Replacement
必要な工具と部品
    1. TI-Nspire Battery Replacement, Battery: 手順 1、 1の画像 1
      • Face the side of the calculator with the "Texas Instruments" logo towards you, with the logo upright.
      • Slide the front cover down to remove it.
      FixBotに聞いてみる
      コメントを追加
    2. TI-Nspire Battery Replacement: 手順 2、 2の画像 1 TI-Nspire Battery Replacement: 手順 2、 2の画像 2
      • The calculator should be facing front with the screen on the top and the keypad on the bottom.
      • Hold the long side of the calculator on the right or left and turn it 180 degrees so that the back of the calculator faces you.
      • Make sure that the current side facing you is the back by checking that the side has a "reset" button.
      FixBotに聞いてみる
      コメントを追加
    3. TI-Nspire Battery Replacement: 手順 3、 1の画像 1
      • Locate the area with a switch on the bottom half of the calculator. Make the sure the switch is on the left side of the switch area, which indicates that it is locked.
      • Slide the switch until it moves from the left side of the button area all the way to the right side.
      • Make sure to hear a click once you move the switch all the way to the right, which indicates the keypad is now removable.
      FixBotに聞いてみる
      コメントを追加
    4. TI-Nspire Battery Replacement: 手順 4、 1の画像 1
      • Turn the calculator back to the front as you would normally use it.
      FixBotに聞いてみる
      コメントを追加
    5. TI-Nspire Battery Replacement: 手順 5、 2の画像 1 TI-Nspire Battery Replacement: 手順 5、 2の画像 2
      • Put your hand on the keypad, slide the keypad down about a half inch, and pull up to remove the keypad.
      FixBotに聞いてみる
      コメントを追加
    6. TI-Nspire Battery Replacement: 手順 6、 1の画像 1
      • The batteries should be on the right and left side in the keypad area, with two on each side.
      • Place the tip of your finger in between the batteries, and remove the batteries. Repeat this for the other side as well.
      FixBotに聞いてみる
      コメントを追加
    7. TI-Nspire Battery Replacement: 手順 7、 1の画像 1
      • When reassembling your device, use four new batteries.
      FixBotに聞いてみる
      コメントを追加
終わりに
To reassemble your device, follow these instructions in reverse order. If your calculator doesn't turn on, it could be that the keypad isn't connected properly. If so, refer to Connecting the Keypad.
キャンセル: このガイドを終了できませんでした。
7 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Clincy Cheung
メンバー登録日: 09/26/12
223 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 7-52, Forte Fall 2012 Cal Poly, Team 7-52, Forte Fall 2012人のメンバー
CPSU-FORTE-F12S7G52
5 メンバー
33のガイドは作成済み
1件のガイドコメント
what should i do if it just stopped all of a sudden and my battery isn’t like that? Its a square not like A++
nenene kldbfssm - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 42
今までの合計 18,108
