メインコンテンツにスキップ
TDK Life on Record Trek Max A34 Small Speaker Replacement
必要な工具と部品
  1. TDK Life on Record Trek Max A34 Small Speaker Replacement, Small Speaker: 手順 1、 2の画像 1 TDK Life on Record Trek Max A34 Small Speaker Replacement, Small Speaker: 手順 1、 2の画像 2
    • Use a TR7 screwdriver to remove the screws from the battery cover located on the underside of the device.
    • Remove the battery cover.
  2. TDK Life on Record Trek Max A34 Small Speaker Replacement: 手順 2、 2の画像 1 TDK Life on Record Trek Max A34 Small Speaker Replacement: 手順 2、 2の画像 2
    • Unplug and remove the battery.
    • Use a metal spudger to pry off the rubber padding.
  3. TDK Life on Record Trek Max A34 Small Speaker Replacement: 手順 3、 3の画像 1 TDK Life on Record Trek Max A34 Small Speaker Replacement: 手順 3、 3の画像 2 TDK Life on Record Trek Max A34 Small Speaker Replacement: 手順 3、 3の画像 3
    • Use a J00 screwdriver to unscrew the screws that are under the rubber pads.
    • Remove the battery holder and be sure to thread the wires through the hole within the part.
  4. TDK Life on Record Trek Max A34 Small Speaker Replacement: 手順 4、 3の画像 1 TDK Life on Record Trek Max A34 Small Speaker Replacement: 手順 4、 3の画像 2 TDK Life on Record Trek Max A34 Small Speaker Replacement: 手順 4、 3の画像 3
    • Use a metal spudger to pry off the front and back mesh screens.
    • You may need to move the metal spudger along the edge of the screen to remove it easier.
  5. TDK Life on Record Trek Max A34 Small Speaker Replacement: 手順 5、 3の画像 1 TDK Life on Record Trek Max A34 Small Speaker Replacement: 手順 5、 3の画像 2 TDK Life on Record Trek Max A34 Small Speaker Replacement: 手順 5、 3の画像 3
    • Use the a metal spudger to pry up the rubber cover on the top surface of the device.
    • Peel off the rubber cover to reveal the buttons and screws underneath.
  6. TDK Life on Record Trek Max A34 Small Speaker Replacement: 手順 6、 2の画像 1 TDK Life on Record Trek Max A34 Small Speaker Replacement: 手順 6、 2の画像 2
    • Use a J00 screwdriver to unscrew the screws that hold the top cover in place.
    • Remove the top cover.
  7. TDK Life on Record Trek Max A34 Small Speaker Replacement: 手順 7、 2の画像 1 TDK Life on Record Trek Max A34 Small Speaker Replacement: 手順 7、 2の画像 2
    • On the backside of the device, unscrew the case screws with a J00 screwdriver.
    • Only the screws on the backside are needed to hold the frame together, do not remove screws on the front.
    • Once the screws are removed, separate the two frame pieces.
  8. TDK Life on Record Trek Max A34 Small Speaker Replacement: 手順 8、 3の画像 1 TDK Life on Record Trek Max A34 Small Speaker Replacement: 手順 8、 3の画像 2 TDK Life on Record Trek Max A34 Small Speaker Replacement: 手順 8、 3の画像 3
    • The following steps can be applied to either the left or the right speaker.
    • Use a J00 screwdriver to unscrew the four screws that secure the speaker.
    • The speaker should fall out naturally. If the speaker is stuck, use a plastic opening tool or a metal spudger to gently lift it out.
    • Desolder the black and red speaker wires.
    • Review the Desolder guide if you are unfamiliar with soldering.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Mario Lazaga
メンバー登録日: 01/14/19
1 ポイント
2のガイドは作成済み
チーム
IUPUI, Team S3-G3, Wilson Spring 2019 IUPUI, Team S3-G3, Wilson Spring 2019人のメンバー
IUPUI-WILSON-S19S3G3
3 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 8
今までの合計 336
