メインコンテンツにスキップ
TDK Life on Record Trek Max A34 Buttons Replacement
必要な工具と部品
  1. TDK Life on Record Trek Max A34 Buttons Replacement, Battery: 手順 1、 2の画像 1 TDK Life on Record Trek Max A34 Buttons Replacement, Battery: 手順 1、 2の画像 2
    • Flip your device upside down so the battery cover is facing upwards.
    • Using the Torx T6 screwdriver, remove all seven 6 mm Torx screws that are located along the perimeter of the battery cover.
  2. TDK Life on Record Trek Max A34 Buttons Replacement: 手順 2、 2の画像 1 TDK Life on Record Trek Max A34 Buttons Replacement: 手順 2、 2の画像 2
    • Use the metal spudger prying tool to gently pry off the battery cover.
    • The battery should now be exposed.
  3. TDK Life on Record Trek Max A34 Buttons Replacement: 手順 3、 3の画像 1 TDK Life on Record Trek Max A34 Buttons Replacement: 手順 3、 3の画像 2 TDK Life on Record Trek Max A34 Buttons Replacement: 手順 3、 3の画像 3
    • Starting from where the wires are connected, gently pull the battery out of the device.
  4. TDK Life on Record Trek Max A34 Buttons Replacement: 手順 4、 2の画像 1 TDK Life on Record Trek Max A34 Buttons Replacement: 手順 4、 2の画像 2
    • Unplug the battery from the device by detaching the wires at the white connection box.
    • Detaching the wires may require some force.
    • Be careful not to rip the wires out of the device or the battery.
  5. TDK Life on Record Trek Max A34 Buttons Replacement: 手順 5、 1の画像 1
    • The battery is now separated from the device and may be replaced with a new battery.
  6. TDK Life on Record Trek Max A34 Buttons Replacement, Large Speaker: 手順 6、 2の画像 1 TDK Life on Record Trek Max A34 Buttons Replacement, Large Speaker: 手順 6、 2の画像 2
    • Turn over the device so the bottom is facing up. Remove the screws of the battery cover using the iFixit TR7 screwdriver.
    • Remove the battery cover by pulling up where the screws should go.
  7. TDK Life on Record Trek Max A34 Buttons Replacement: 手順 7、 2の画像 1 TDK Life on Record Trek Max A34 Buttons Replacement: 手順 7、 2の画像 2
    • Carefully unplug and remove the battery.
    • Use the metal spudger to pry off the rubber bumpers from the bottom of the speaker.
  8. TDK Life on Record Trek Max A34 Buttons Replacement: 手順 8、 3の画像 1 TDK Life on Record Trek Max A34 Buttons Replacement: 手順 8、 3の画像 2 TDK Life on Record Trek Max A34 Buttons Replacement: 手順 8、 3の画像 3
    • Use a Phillips #00 screwdriver to remove the screws that were underneath the rubber bumpers.
    • Remove the battery holder. Be sure to thread the exposed wires through the hole within the holder.
  9. TDK Life on Record Trek Max A34 Buttons Replacement: 手順 9、 3の画像 1 TDK Life on Record Trek Max A34 Buttons Replacement: 手順 9、 3の画像 2 TDK Life on Record Trek Max A34 Buttons Replacement: 手順 9、 3の画像 3
    • Use a metal spudger to pry off the front and back mesh screens.
    • You may need to move the metal spudger along the edge of the screen to remove it more easily.
  10. TDK Life on Record Trek Max A34 Buttons Replacement: 手順 10、 3の画像 1 TDK Life on Record Trek Max A34 Buttons Replacement: 手順 10、 3の画像 2 TDK Life on Record Trek Max A34 Buttons Replacement: 手順 10、 3の画像 3
    • Turn the speaker back upright. Use the metal spudger to pry up the rubber cover to reveal the buttons underneath.
  11. TDK Life on Record Trek Max A34 Buttons Replacement: 手順 11、 2の画像 1 TDK Life on Record Trek Max A34 Buttons Replacement: 手順 11、 2の画像 2
    • Use a Phillips #00 screwdriver to remove the screws that hold the top cover in place.
    • Remove the top cover.
  12. TDK Life on Record Trek Max A34 Buttons Replacement: 手順 12、 2の画像 1 TDK Life on Record Trek Max A34 Buttons Replacement: 手順 12、 2の画像 2
    • On the backside of the device, remove the screws using the Phillips #0 screwdriver.
    • Only the screws on the backside are needed to hold the frame together. Do not remove screws on the front.
    • Once the screws are removed, separate the two frame pieces.
  13. TDK Life on Record Trek Max A34 Buttons Replacement: 手順 13、 1の画像 1
    • Within the device, there is a single cable connecting the large speaker to the motherboard. Unplug this cable.
  14. TDK Life on Record Trek Max A34 Buttons Replacement: 手順 14、 2の画像 1 TDK Life on Record Trek Max A34 Buttons Replacement: 手順 14、 2の画像 2
    • On the front of the device, use the Phillips #0 screwdriver to remove the four screws holding the speaker in.
    • Once the screws are removed, you are able to push the speaker out from behind.
  15. TDK Life on Record Trek Max A34 Buttons Replacement, Small Speaker: 手順 15、 2の画像 1 TDK Life on Record Trek Max A34 Buttons Replacement, Small Speaker: 手順 15、 2の画像 2
    • Use a TR7 screwdriver to remove the screws from the battery cover located on the underside of the device.
    • Remove the battery cover.
  16. TDK Life on Record Trek Max A34 Buttons Replacement: 手順 16、 2の画像 1 TDK Life on Record Trek Max A34 Buttons Replacement: 手順 16、 2の画像 2
    • Unplug and remove the battery.
    • Use a metal spudger to pry off the rubber padding.
  17. TDK Life on Record Trek Max A34 Buttons Replacement: 手順 17、 3の画像 1 TDK Life on Record Trek Max A34 Buttons Replacement: 手順 17、 3の画像 2 TDK Life on Record Trek Max A34 Buttons Replacement: 手順 17、 3の画像 3
    • Use a J00 screwdriver to unscrew the screws that are under the rubber pads.
    • Remove the battery holder and be sure to thread the wires through the hole within the part.
  18. TDK Life on Record Trek Max A34 Buttons Replacement: 手順 18、 3の画像 1 TDK Life on Record Trek Max A34 Buttons Replacement: 手順 18、 3の画像 2 TDK Life on Record Trek Max A34 Buttons Replacement: 手順 18、 3の画像 3
    • You may need to move the metal spudger along the edge of the screen to remove it easier.
  19. TDK Life on Record Trek Max A34 Buttons Replacement: 手順 19、 3の画像 1 TDK Life on Record Trek Max A34 Buttons Replacement: 手順 19、 3の画像 2 TDK Life on Record Trek Max A34 Buttons Replacement: 手順 19、 3の画像 3
    • Use the a metal spudger to pry up the rubber cover on the top surface of the device.
    • Peel off the rubber cover to reveal the buttons and screws underneath.
  20. TDK Life on Record Trek Max A34 Buttons Replacement: 手順 20、 2の画像 1 TDK Life on Record Trek Max A34 Buttons Replacement: 手順 20、 2の画像 2
    • Use a J00 screwdriver to unscrew the screws that hold the top cover in place.
  21. TDK Life on Record Trek Max A34 Buttons Replacement: 手順 21、 2の画像 1 TDK Life on Record Trek Max A34 Buttons Replacement: 手順 21、 2の画像 2
    • On the backside of the device, unscrew the case screws with a J00 screwdriver.
    • Only the screws on the backside are needed to hold the frame together, do not remove screws on the front.
  22. TDK Life on Record Trek Max A34 Buttons Replacement: 手順 22、 3の画像 1 TDK Life on Record Trek Max A34 Buttons Replacement: 手順 22、 3の画像 2 TDK Life on Record Trek Max A34 Buttons Replacement: 手順 22、 3の画像 3
    • The following steps can be applied to either the left or the right speaker.
    • Use a J00 screwdriver to unscrew the four screws that secure the speaker.
    • The speaker should fall out naturally. If the speaker is stuck, use a plastic opening tool or a metal spudger to gently lift it out.
    • Desolder the black and red speaker wires.
    • Review the Desolder guide if you are unfamiliar with soldering.
  23. TDK Life on Record Trek Max A34 Buttons Replacement, Motherboard: 手順 23、 3の画像 1 TDK Life on Record Trek Max A34 Buttons Replacement, Motherboard: 手順 23、 3の画像 2 TDK Life on Record Trek Max A34 Buttons Replacement, Motherboard: 手順 23、 3の画像 3
    • Carefully detach the 4 white rectangular clips from the motherboard.
  24. TDK Life on Record Trek Max A34 Buttons Replacement: 手順 24、 1の画像 1
    • Carefully remove the motherboard from the device.
  25. TDK Life on Record Trek Max A34 Buttons Replacement, Buttons: 手順 25、 2の画像 1 TDK Life on Record Trek Max A34 Buttons Replacement, Buttons: 手順 25、 2の画像 2
    • Once the soldering iron is heated, carefully place the iron onto the connection point of the button.
    • With a steady hand, hold the soldering iron in place until the metal is slightly melted.
    • For more information on soldering and desoldering connections, please read the How to Solder and Desolder Connections guide.
  26. TDK Life on Record Trek Max A34 Buttons Replacement: 手順 26、 1の画像 1
    この手順で使用する道具:
    購入する
    • Use a pair of tweezers to remove the buttons.
    • Repeat the previous step for multiple buttons.
終わりに
作成者
2人の作成者と共同で作成されました。
Marilyn Ho
メンバー登録日: 11/04/19
211 ポイント
2のガイドは作成済み
チーム
IUPUI, Team S1-G3, Harley Fall 2019 IUPUI, Team S1-G3, Harley Fall 2019人のメンバー
IUPUI-HARLEY-F19S1G3
3 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 12
今までの合計 353
