メインコンテンツにスキップ
System x3650 CPU and Memory Replacement
必要な工具と部品
  1. System x3650 CPU and Memory Replacement, CPU and Memory: 手順 1、 2の画像 1 System x3650 CPU and Memory Replacement, CPU and Memory: 手順 1、 2の画像 2
    • Make sure that you have unplugged the power cable before servicing.
    • Pull the latch on the top cover up.
    • Slide the cover out.
  2. System x3650 CPU and Memory Replacement: 手順 2、 3の画像 1 System x3650 CPU and Memory Replacement: 手順 2、 3の画像 2 System x3650 CPU and Memory Replacement: 手順 2、 3の画像 3
    • Press the two latches on the riser card assembly, indicated by blue arrows and outlines.
    • Slowly take the the riser card assembly out.
    • Doing so will allow you to remove the white plastic airflow guides.
    • This will provide access to the computer parts that you want to replace.
  3. System x3650 CPU and Memory Replacement: 手順 3、 1の画像 1
    • Move the heat sink bracket lever to the open position and remove the heat sink.
    • This will provide access to the processor.
  4. System x3650 CPU and Memory Replacement: 手順 4、 2の画像 1 System x3650 CPU and Memory Replacement: 手順 4、 2の画像 2
    • Open the CPU retention bracket lever.
    • Remove the old processor from the socket.
  5. System x3650 CPU and Memory Replacement: 手順 5、 2の画像 1 System x3650 CPU and Memory Replacement: 手順 5、 2の画像 2
    • Remove the old RAM if it is being replaced.
    • Unfasten the clamps on both ends of the slot.
    • Take out the memory module.
  6. System x3650 CPU and Memory Replacement: 手順 6、 2の画像 1 System x3650 CPU and Memory Replacement: 手順 6、 2の画像 2
    • Insert the new memory modules into the empty RAM slots securely.
    • The clamps on both ends of the slot should click into place.
    • See this link for the DIMM installation sequence.
  7. System x3650 CPU and Memory Replacement: 手順 7、 3の画像 1 System x3650 CPU and Memory Replacement: 手順 7、 3の画像 2 System x3650 CPU and Memory Replacement: 手順 7、 3の画像 3
    • Insert new CPU into socket.
    • Ensure that the CPU chip is positioned correctly (i.e. its marked corner is facing bottom left).
    • Apply thermal paste to the top of the processor if necessary.
    • Close the CPU retention bracket lever.
    • An insecure or improper placement can damage a CPU or the socket pinout.
  8. System x3650 CPU and Memory Replacement: 手順 8、 1の画像 1
    • Place the heat sink on top of the CPU.
    • Move the heat sink bracket lever to closed position.
  9. System x3650 CPU and Memory Replacement: 手順 9、 3の画像 1 System x3650 CPU and Memory Replacement: 手順 9、 3の画像 2 System x3650 CPU and Memory Replacement: 手順 9、 3の画像 3
    • If you need to add a second processor, move the heat sink bracket lever to open position.
    • Take out the white plastic cover on the second socket.
    • Repeat steps 7 and 8 for the second CPU/socket (insert a CPU and a heat sink).
  10. System x3650 CPU and Memory Replacement: 手順 10、 3の画像 1 System x3650 CPU and Memory Replacement: 手順 10、 3の画像 2 System x3650 CPU and Memory Replacement: 手順 10、 3の画像 3
    • Insert the plastic airflow guides back in their places.
    • Insert the riser card assembly, pushing it into its slot.
  11. System x3650 CPU and Memory Replacement: 手順 11、 2の画像 1 System x3650 CPU and Memory Replacement: 手順 11、 2の画像 2
    • Slide the top cover in place firmly.
    • Ensure that the latch is in the down position.
終わりに
Follow this guide to replace or upgrade CPU and memory on IBM System x3650. Up to 2 processors can be installed. Up to 48 GB of RAM can be installed.
作成者
3人の作成者と共同で作成されました。
Serguei Potechnykh
メンバー登録日: 09/16/20
193 ポイント
1ガイドが承認済み
チーム
York University, Team S2-G21, Melo-Thaiss Fall 2020 York University, Team S2-G21, Melo-Thaiss Fall 2020人のメンバー
YORK-MELO-THAISS-F20S2G21
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 12
過去 30 日: 47
今までの合計 2,413
